996 Forum 1999-2005
tensioner and IMS removal
Old 02-06-2018, 02:24 AM
Ahsai
Ahsai's Avatar
Originally Posted by steve578
I’m changing out the IMS bearing on my 3-chain engine sometime in the new few weeks. Can someone confirm that the bank-2 tensioner under the AC compressor can be left in place? I have it in my notes that it doesn’t need to be removed, but this thread has me second guessing myself.
You are most likely ok.
Old 02-06-2018, 09:25 AM
steve578
steve578's Avatar
Thanks. I saw your original response. Everything referenced 5-chain as okay, but haven't seen 3-chain referenced.
Old 02-06-2018, 02:20 PM
jumpy chunky
jumpy chunky's Avatar
Thanks to everyone who replied to my thread.
I will try once again to remove without taking apart the intake plenum.
If the intake plenum is removed would that facilitate the removing and replacement
of my broken oil fill pipe as well?
Anyway, thanks again for the posts..
Old 02-06-2018, 06:33 PM
Kris Murphy
Kris Murphy's Avatar
Originally Posted by Slakker
Or just disconnect the AC lines. Ideally you capture the discharge but if you don't, it is the equivalent to burning about 150 gallons of gas. So not catastrophic but not something you'd want to do everyday. There may be legal ramifications for not capturing it that I'm not aware as well.
I know in PA it is a $10,000 fine.
Old 02-06-2018, 09:54 PM
Slakker
Slakker's Avatar
Yikes!!!
Old 02-06-2018, 11:42 PM
Ahsai
Ahsai's Avatar
The IMS is supported by the oil pump on the opposite end of the IMSB. You can see that when the bank 2 tensioner is kept in place, the bank 2 timing chain tends to pull the IMS to the right but such movement will be restricted by the oil pump. In contrast on the IMSB end, the bank 1 timing chain will pull the IMS to the left (movement normally restricted by the IMSB flange). If you remove the IMSB flange without removing the bank 1 tensioner, you will find the IMS off center to the left and you are screwed.
When the engine is parked at TDC with cam lock tool installed in bank 1 cams, there is very little tendency for the 4 cams to rotate. There's some but it's minimal and it won't be enough to rotate the IMS.
Quick Reply: tensioner and IMS removal
