996 Forum 1999-2005
Does this look normal to y'all? Butt connectors everywhere.. lol
Old 01-11-2018, 03:41 PM
yamasaki
yamasaki's Avatar
Default Does this look normal to y'all? Butt connectors everywhere.. lol
I forgot to ask the other day... i saw this army of butt connectors going to my headlight the other day when i was changing out the bulbs. is this original/normal ?
Old 01-11-2018, 03:48 PM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
No. Maybe the P.O. upgraded to hids/BiExnons??
Old 01-11-2018, 03:51 PM
yamasaki
yamasaki's Avatar
Thats what i was thinking too. and that cut ground wire looks an old amplifier ground.
Old 01-12-2018, 02:53 PM
ChicagoSpeed996
ChicagoSpeed996's Avatar
Yeah that would be my guess. Went to HIDs or LEDs.
Old 01-16-2018, 08:24 AM
yamasaki
yamasaki's Avatar
I started working on my double din upgrade. the butt connectors were more than likely from an aftermarket amp. they were all going to the HAES 40x6 amp (m680).
Looks like the PO took alot of time to return the audio system to stock before selling it. I'm taking the haes out also and putting in a small rockford fosgate that supports 2ohms (eliminating the dsp).
Old 01-16-2018, 08:44 AM
yamasaki
yamasaki's Avatar
progress.... test fitting A/C relocation and double din kit from metra
lots of dremeling. nervous level 50 of 100. lol.
Old 01-16-2018, 08:46 AM
yamasaki
yamasaki's Avatar
I also had to customize the way the radio is secured into the kit. the braces that came with the kit were too big and were hitting the a/c vents behind the dash. it wouldn't go all teh way in.
i just drilled some holes in the side of the kit and screwed the radio into the kit so it's all one piece. way more secure than the way it came/designed.
I would've been 100% finished yesterday but i learned a hard lesson about DSP and the stock amp that I hadn't foreseen or researched well enough i guess.
So, waiting for my new amp...... c'mon amazon prime....
also will be installing a backup camera and replace the cigarette lighter with a USB/HDMI solution from another radio thread on here. great idea.
Old 01-16-2018, 08:59 AM
yamasaki
yamasaki's Avatar
So, looks like now i need to figure out
a) if i have stock speakers
2) if i do, how to wire them up in 2ohm configuration
I'm assuming all of the speaker wires I need are accessible from the stock amp location and the harnesses/wires that are all already there.
Quick Reply: Does this look normal to y'all? Butt connectors everywhere.. lol
