IMSB Removal, Easiest With Shaft in engine or Out?
Is there an advantage to removing the IMSB while the shaft is in the car before halving the cases? Seems like some tools bolt to the case and some don't.
Thanks!
Thanks!
The IMS Pro Tool Kit's pulley gets leverage from the end of the intermediate shaft itself, so regardless of whether the IMS shaft is in the engine or on the bench, the same pulley will work in either situation.
You may have other reasons to do so, but there's no need to split that engine for IMSB replacement.
With the right tools (including IMS Pro Toolkit) the engine stays (almost) fully assembled. Transmission, clutch, & flywheel are removed to expose the "output" end of the engine. You then use those special tools to remove the old IMSB and install the new one.
