Newbie - First Posting - Page 2 - Rennlist - Porsche Discussion Forums
996 Forum
Sponsored by: LN Engineering
Old 01-03-2018, 05:18 PM
Anestheticg
User
Originally Posted by rolex11 View Post
Any chance you could point out what kit over on ebay you ordered. I looked and my head started spinning. I know zero about electrical thingy's. But with the DIY pdf. I have a chance.
Thanks.
i have to take a look at the packaging I may have around when i get home. I ordered 5k 55w and Iím pretty sure one of the bulbs was 6k. Good customer service and sent me 2 new bulbs but havenít bothered to swap em as itís so subtle and I donít want to mess with the headlights housings again. Will let you know ASAP. Btw I got a 16570, 116610LV, and blue 326934.
Anestheticg is offline
Old 01-03-2018, 05:39 PM
cds72911
Do the LED heat sink/fans/etc fit in the 996 housings? If so, this could be a nice upgrade. I've had the upgraded LED bulbs on a couple of motorcycles and they're a lot better than the stock halogens.
cds72911 is offline
Old 01-03-2018, 10:39 PM
rolex11
User
Cool. Would help to know what, and from which vendor you got yours.
Very much into horology and own more than a few high end pieces, but not a Rolex in the bunch.
rolex11 is offline
Old 01-04-2018, 01:25 AM
tomcat
tomcat's Avatar
i took off an LL Tek CAI that came with my car when I got it. If you are interested, let me know. Iím across the river.
tomcat is offline
Old 01-04-2018, 07:12 AM
dan_189
User
Welcome,
FWIW there is a write-up somewhere that someone's done on installing heated seats ill try and find it. It is possible just not easy.
Spoilers for your car there are a few available for OEM options check out the tequipment brochure which outlines everything. There are also pleanty of options too.
​​The lingo just takes time, you'll get there!
Also you can download a PDF manual for free or grab one off ebay.
dan_189 is offline
Old 01-04-2018, 11:22 AM
Anestheticg
User
surprising given your handle 😂. Anyway, this is the website I ordered from. It will tell you bulb size (I believe C2 is H7 size) and I got 5k 55w
https://kensun.com/
Old 01-04-2018, 07:10 PM
lowpue
lowpue's Avatar
https://kensun.com/
Was there any customization that was needed with mounting or connectors? Did you just stuff the ballast inside the headlight assembly? Do you get a fault code for using less power? Once you answer this I am ordering this system.
lowpue is offline
Old 01-04-2018, 07:39 PM
Anestheticg
User
i mounted ballast outside headlight assembly. They were zip tied to other lines outside assembly. You have to cut a small hole to run wires through on the black back plate of the housing. Or you can put them in housing but they may get warm. No fault codes. Good luck
Old 01-05-2018, 01:50 PM
lowpue
lowpue's Avatar
I am going to ask a dumb question: H7 is low beam only (I think), what did you do with high beam? Not even sure I know where the high beam is on 996.1?
lowpue is offline
Old 01-05-2018, 02:10 PM
cds72911
To the best of my knowledge, the high, low and fog bulbs are all H7 (three of them, six total), they just have different reflectors. You access them all, by removing the lens assembly from the vehicle, and popping off the protective cover at the back.
The LED retrofits I've used are plug and play in factory housings (unlike the bi-xenon projector HIDs I've done, which require surgery: lens removal, dremel work, etc.). The main question I have is whether there is room for the bulky back of the LED light assembly in the factory housings of the 996.
LEDs throw a lot of light, but if you can get away with it where you live, bi-xenon projector HIDs have a lot more usable light and clean cutoff on the low beam setting. My state has gotten draconian about DOT marked lenses, so it is harder to make upgrades like this anymore. I've had annual safety inspections fail with LED lights - even though they were clearly superior to OEM halogens - on a technicality of our inspection regs.
cds72911 is offline
Old 01-05-2018, 03:00 PM
Anestheticg
User
i just did the low beam bulb swap. They are aimed appropriately and super bright. I left the stock bulbs for brights and when on they cast the beam higher but it is so dim in camparison to the HID that they are pretty much redundant and not needed
Old 01-05-2018, 05:18 PM
lowpue
lowpue's Avatar
Do you have any issues with blinding people....
So then here is my next question....Would it make sense to use 35W HIDs for low beam and 55W HIDs for high beam. THis way the low beams are not too blinding? I am asking all of these questions since I will be buying a set this weekend.
lowpue is offline
Old 01-05-2018, 05:56 PM
Anestheticg
User
I suppose you could do that. 55w is probably a bit overkill. I opted to not swap out high beams because of the type of driving I do. I usually only need to flash someone rarely and HID have that brief warm up period that makes them impractical for that use. I have never been flashed by people thinking I have my high beams on. My low beams HID are very bright but they are aimed appropriately. I think a higher riding suv with LED a la Acura MDX is more of s safety issue than my retro fit 55w bulbs
Old 01-06-2018, 02:48 AM
lowpue
lowpue's Avatar
You are a wealth of information Thank you. One last question....how long does it take the HID to warm up?
lowpue is offline
Old 01-06-2018, 10:12 AM
Anestheticg
User
Around 3-5 seconds
Related Topics
Thread
Forum
Replies
Last Post
phantasylink
Vehicle Marketplace
5
01-13-2018 01:03 AM
gtntahg
997 Forum
10
01-08-2018 07:46 PM
1loud_RS
Vehicle Marketplace
21
01-31-2017 05:22 PM
Franko T
991
6
10-19-2016 05:33 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 1998 - 2017 Rennlist.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
Question Title:
