Pics of how the rear belts are mounted?
HI I am trying to put the rear belts back in (02 coupe) and can seem to figure out how they are mounted behind the c pillar trim. Are they mounted to a bracket?
Thanks.
Thanks.
behind the side window there is a cap/cover.plastic on most cars. Pop the cap off and it bolts in there.
There is a bracket that they sit in, see this diagram:
The base/retractor sits and bolts into a bracket that is then bolted down onto the body with three bolts (the bracket cannot be seen in the diagram above)
Thanks, thats what I had thought. Now who has a set of those brackets?!
http://www.autoatlanta.com/porsche-p...650479700GRV#a22Bracket
(DRIVER SIDE)1-99650479700GRVPrime Coated Belt$89.27(22)Bracket
(PASSENGER SIDE)1-99650479800GRVPrime Coated Belt$89.27
Here is what's under the panels:
