Differences between 3.4 engines
I'm looking at used engines for my '99 996. There are a couple of them on eBay, one is a 1999 M96.01 engine and one is a 2000 M96.04. The '99 has a mechanical throttle and the 2000 has electronic. I need the mechanical one and It's an easy conversion. Besides that, are there any differences I should be concerned about? Is there a preference for one over the other?
I just did this last year.
1. You need to swap the throttle body.
2. You need to swap the entire engine wiring harness. Just do it one connection at a time and you will be fine.
3. You may need to swap the fuel rails. Some cars have the fuel lines going through the AC compressor for fueling.
I did both swaps in under 4 hours (included removing both wiring harnesses.
Great info Kris!
