Durametric question
Durametric question
Apparently i need to source one of these in order to do a brake fluid flush given i have PASM and need something to actuate the valves. My question is, will the enthusiast model accomplish this or do i need the pro version? I've searched and looked with no definitive answer, thanks in advance.
May want to wait for someone to double check as I have not personally owned one but everything I read says that the only real difference is the amount of Vins that can be linked. The pro is unlimited or something and the enthusiast model allows for use on 3 vins I believe..
But someone will chime in and confirm.
Received 1,085 Likes
Yes, it does do the brake bleeding activations. Get the enthusiast version and you will be good to go. http://www.durametric.com/modelfeaturematrixv6.aspx
Like DBJoe said, it will actuate the PSM for your flush. However - it technically isn’t necessary unless you got air in the abs system. When I was doing my front brakes I had to remove both calipers for several days. After reinstalling I used a motiv bleeder and flushed the system (didn’t have a durametric at the time) and it worked perfectly. Granted there may be a little old fluid left so it may not have been a 100% flush.
Charlie
Charlie
Guess i need to do some more research, I only plan on pads and a flush for now so perhaps i can do that without the Durametric? Is it only if you pull calipers off (or otherwise introduce air into system) that opening the abs valves is necessary? I'm gonna repaint the callipers in the spring, so i may just rely upon my torque app for any scanning needed until then (realize i can't open valves with torque).
The only headache for me is buying another laptop, but i need to do this anyway as the aftermarket amplifiers require windows based software to program -Pcpu, lol.
Good lookin out, but i had planned on just (mostly) draining the reservoir and then bleeding at the caliper with my speed bleeder (not motive). I don't have to pressurize the reservoir do I?
And the correct cap (Pelican Kit has this)
https://www.motiveproducts.com/pages/application-guide
I removed both front calipers for a week - they dripped and drained the fluid reservoir completely. I used a Motive power bleeder and no durametric and it worked fine - 0 issues. So, if you're not evening removing calipers and just want to flush through fluid - then you definitely don't need it. It may not get every last drop of the old fluid, but especially if you're going to be doing this again in the spring - I wouldn't bother.
I'm not sure what speed bleeder you have - but if you've used it before and are happy with it, no reason to think it wouldn't work. The only caveat is that if it screws onto the reservoir you need the correct cap to thread to it. I bought a Motive with the porsche/euro cap on Amazon for $50 last year and it is the greatest thing ever. If you've ever bled brakes the old fashioned way (ie, someone sits in the car and presses the pedal while you loosen and tighten the bleeder vales) then you know it is a nightmare and generally a complete waste of time. I've installed a new slave cylinder + flush and then did a full brake system flush, alone - with the Motive and it all worked flawlessly the first time. No spongy brake pedal and having to go back and redo it due to bubbles.
+1 on motive and not needing durametric. You will definitely want to pressurize the system to flush it.
Also, don’t put the fluid in the motive. Bleed the reservoir down part way, remove the motive, refill reservoir, pressure it back up. It’s a much cleaner way to do it.
