Read current oil pressure from ODB? Race capture pro?
Hi,
I have a race capture pro that can pull data from CAN or ODB.
Is it possible to read current oil pressure from the ODB?
After HPDE session I would like to see what the pressure was.
You are correct, just had a look back through the wiring diagrams, direct from unit to cluster along with the level sensor into cluster
Ok, so seems like I can splice and pull a wire from the sensor directly to Race capture pro.
Would have to calibrate the voltage but that should be easy, just read the voltage and look at the stock gauge.
