996 Forum 1999-2005
Removing Hemlholtz resonator - capping of the hole in airbox
Old 11-13-2017, 08:03 AM
Silk
Silk's Avatar
Default Removing Hemlholtz resonator - capping of the hole in airbox
I am running the IPD Competition plenum and 82mm throttle body.
The IPD-kit comes with a silicon hose to fit the bigger TB. This hose by-passes the Helmholtz resonator. There is a flexible silicone cap to close the open hole of resonator box. Just to prevent dirt to enter, as the box itself is closed off from the airbox itself.
The nicest solution would be to remove the resonator chamber complety from the inside of the air-filter box. as it will free up some space above the filter for air to flow. However then I will need something else to close the hole in the airbox as in the current situation the neck of the resonator sticks through the hole, the IPD cap is fitted on this neck. When removing the box there will be no support to mount something on.
I have seen the so called 'orange cap' suggested. But this cap is unavailable. Any other DIY alternatives that will work?
Fabspeed has a cap that comes with their intake hose kit. http://www.fabspeed.com/996-carrera-...r-upgrade-kit/
It will fit from inside into the hole and screws into the existing holes where the renoator is fixed.
Old 11-13-2017, 08:15 AM
hatchetf15
hatchetf15's Avatar
I removed the complete resonator, then Dremel-tooled the top of the old resonator to mimic the Fabspeed neck and bonded the neck to top of airbox cover. Hasn't budged after thousands of miles.
Old 11-13-2017, 08:36 AM
Silk
Silk's Avatar
Okay ... after some googling with slight different keywords then I used before starting this thread I came across this post
https://rennlist.com/forums/996-foru...irbox-mod.html
Here a 2inch 'gripper' plug is used to cap the hole.
996-CAB (09-29-2023)
Old 11-13-2017, 10:32 AM
Southern Man
Southern Man's Avatar
I used the same Oatay plug, but to make it work I ended up buying two, with one on the inside. Easy.
Old 11-13-2017, 11:22 AM
HawkFan#12
HawkFan#12's Avatar
That’s the one I am using.
Old 11-13-2017, 01:52 PM
cds72911
cds72911's Avatar
What is the up side or benefit from removing the guts versus just capping it?
I have the ipd comp plenum and just covered the opening with the provided cap. I’m always interested in tweaks to improve the car.
Thanks!
Old 11-13-2017, 04:55 PM
hatchetf15
hatchetf15's Avatar
The resonator cancels certain frequencies in the lower rpm ranges. Capping the top cancels the effect and allows a more distinct engine "voice" and a little more growl. I removed the resonator, entirely, since I didn't see a need for the obstruction to airflow after the filter and before the butterfly valve. Isn't more airflow the primary purpose for the mod kit in the first place?
Old 11-13-2017, 05:01 PM
cds72911
cds72911's Avatar
Excellent. Thanks. I know what my next project is...
Old 08-02-2019, 07:05 AM
Astro
Astro's Avatar
Question which might be solved by this... I did the muffler delete, it was a bit too droney, so I installed the CC inserts. It eliminated the drone, but when the car is decelerating in gear it gets this raspy sound(almost ricer like). Would this resonator removal get rid of this sound ?
Old 08-02-2019, 10:21 AM
808Bill
808Bill's Avatar
No. Induction noise and exhaust noise are to different animals.
The following 2 users liked this post by 808Bill:
996-CAB (09-29-2023), Mike Murphy (08-02-2019)
Old 08-02-2019, 10:24 AM
hatchetf15
hatchetf15's Avatar
Astro,
Are you referring to exhaust overrun burble noise? So you gutted the muffler or removed it? CC inserts? Any of these exhaust flow variables change flow rates, hence engine frequencies and noises. Exhaust noises are what you’re talking here. Resonator is intake side.
Old 08-02-2019, 10:33 AM
Mike Murphy
Mike Murphy's Avatar
Received 1,577 Likes on 984 Posts
My car has a WRX-like rasp when decelerating as well, and it’s quite loud. It got loud after I did the Fister hack. It’s loudest when the ECU cuts fuel during decel, and when cold. I don’t really care for that sound, but it’s not a big deal. I figure I could always replace the mufflers at some point.
Old 08-02-2019, 02:22 PM
Astro
Astro's Avatar
"Are you referring to exhaust overrun burble noise? So you gutted the muffler or removed it? CC inserts? Any of these exhaust flow variables change flow rates, hence engine frequencies and noises. Exhaust noises are what you’re talking here. Resonator is intake side."
Yes, I removed the mufflers and just have the bypass pipes. Due to drone I installed Car Chemistry inserts which got rid of the drone, but must have changed the exhaust flow rates a little and I'm getting some of the sounds as described in the this other response.
"My car has a WRX-like rasp when decelerating as well, and it’s quite loud. It got loud after I did the Fister hack. It’s loudest when the ECU cuts fuel during decel, and when cold. I don’t really care for that sound, but it’s not a big deal. I figure I could always replace the mufflers at some point."
So when I started looking for threads which might address this issue I came upon the resonator one...
Old 08-02-2019, 02:59 PM
5CHN3LL
5CHN3LL's Avatar
If your car is running rich, or if you're running sport cats or catless, the backfiring will be much more pronounced. My C4 with sport cats and Tubi mufflers made fantastic noises between gears.
Old 08-02-2019, 08:13 PM
Mike Murphy
If you still have the old mufflers, see if putting them back solves the issue.
Quick Reply: Removing Hemlholtz resonator - capping of the hole in airbox
