996 Oil Pressure - 3.6L
I've been looking at a variety of posts where oil pressure has been mentioned and some of the info seems really inconsistent with what I see on my own car.
Generally warm-up just peaks over 4
Normal cruising varies but rarely goes over 4
Highway and higher RPMs between 3 and 4
Idle fluctuates and sometimes seems to bounce around between 1-3
Interested in what others experience and if these seems really off. The car is pretty new to me so I'm always looking at this and wondering if its within reason.
It is not easy to fit a high quality gauge to the car so one can monitor oil pressure while driving.
In the shop the tech could fit a test gauge -- probably 'T' off where the factory sensor is located -- and with the engine warmed up observe hot idle oil pressure and then bring RPMs up to say 5K and note oil pressure at this engine speed.
The factory manual probably has a call out on oil pressure but I don't what off hand this is. (For my 996 Turbo it is "Oil pressure at n=5000 rpm, T = 90C: Approx. 6.5 bar".) (I seem to recall -- but don't quote me -- the factory manual for the 996 NA engine has a slightly lower oil pressure under similar conditions specified.)
In some way you could then "calibrate" (at least in your head) the car's oil pressure reading with the test gauge.
(I did this with the coolant gauge of both my cars. I observed the OBD2 coolant temperature vs. needle position over time and thought I had it all worked out. But after a while I just said to heck with it. I don't need to know the exact coolant temperature only that the engine is cold, warm/hot, or too hot and the temperature gauge is plenty good enough for that.)
Based on what you posted the numbers are in the ballpark.
BTW, my Turbo's oil gauge needle bounces around a bit sometimes when the engine is up to temperature and idling. Been doing this for as long as I can remember ever since I bought the used in 2009. There is probably a marginal connection or the sender or sensor is flaky (?) but the sender is hard to get to and I haven't bothered to replace this. If it were easier to get to I might try a disconnect then a connect to see if this improves the sensor's behavior. (Surface corrosion can develop that can interfere with the voltage signal sent to the DME and if this is the case a disconnect/reconnect can be the cure.)
996 Oil Pressure low
I just replaced the oil sender unit on my 2002 911 4S a few months ago and the oil pressure seems a bit erratic.
My 996 used to start at 4.5 bars, then consistently go down to 3.5 when warm and stay there.
Now it starts at 5, eventually starts going down to 3.5 when warm, then goes down between 1 and 2 when in neutral.
When I step on the pedal, it goes back up to 4.5 - 5.
Is that normal?
If not, any ideas (e.g. replace Sender Unit again in case new one is faulty)?
Is that normal?
Last edited by RossKatz; 03-01-2020 at 10:38 PM. Reason: typo and a bit more info on vehicle
That sounds about normal to me based on what my 996.2 does.
Pegged about 4.5ish til warm then hovers around 3 for awhile, then finally 1.5ish when idling.
Once the cars fully warmed up pressure rises with throttle input. Mine had a new sender installed about 2 years ago because I never quite hit 5. Still doesn’t quite reach 5.
RossKatz (03-02-2020)
I just replaced the oil sender unit a few months ago and the only pressure seems a bit erratic.
Now it starts at 5, eventually starts going down to 3.5 when warm, then goes down between 1 and 2 when idle.
Is that normal?
Is that normal?
RossKatz (03-01-2020)
