Cylinder 4 misfire 2003 C4S
https://seafoamsales.com/
There is one flavor that you can add either to the crankcase (oil) to remove gunk from the internals or to the gas to clean the fuel system.
https://seafoamsales.com/auto/
https://seafoamsales.com/faq-ask-jim/
The other product, a spray foam and a video below on using the spray foam to clean motor top end. I did not use this product, I used the tank additive but I have heard a lot of anecdotal positive reviews over the years:
I'll search about the injectors you alluded to or you can advise me here. Better flow, more hp noted on the butt dyno / actual dyno before and afters?
Edit: I did find another thread where you mentioned upgrading from a one hole to four hole design. I also saw that you like RC injectors; me too, I run RC1000's in my Honda.
