Help! I stripped the gear when adjusting the headlamp angle!
Was adjusting the angle of my low beam with the assembly removed from the car, put them back in and realized it’s pointing way too high... tried to turn the gear again and it seemed disengaged!
Removed the headlamp and inspected within the housing to confirm the disengaged gears... but I can’t reach the teeth to turn it. Is there any solution other than taking the entire assembly apart to engage the gear? Help~~~
My left beam is aiming too high ... I’ll be blinding everyone in sight...
