Chewed Up Bolt Found in Oil Pan
#106
You say that nothing broke, blew up, or fell off- sounds good enough for me. Buying more snap-on/mac tools is fun, but I think I'd be well suited to preserving the budget for other maintenance.
#107
Many brands out there and up to you what you feel most comfortable with. I always store it with no compression on spring and ALWAYS do a check on a bolt in vise (just for feel and to insure I hear the click) before using it.
#108
Update
Thought I would post this update for those that followed this thread and provided much welcome advise.
As you know, during my last 3k mile oil change I found a broken bolt and piece of aluminum in my sump. After reading many responses and talking to several Porsche mechanics, I elected to perform some due-diligence steps (shown below) and hoping that the bolt was nothing more than something dropped into motor during some previous work and that there was no internal damage to the motor.
After finally completing the above (except for Blackstone analysis that I should get by tomorrow), I re-installed sump cover (no leaks), installed the new Oil Pressure Sensor, filled with DT40 and started it up preying that all would be good.
After starting up, I was pleased that the motor ran very smooth with no noise what soever, ref Youtube texcwa-996-1 below. After topping off oil, took it for a test drive. Drove it for approx 30 minutes alowing it to warm up then doing some spirited driving. After returning the car was still running smooth with no unusual noised (none at all) and a very smooth idle, ref Youtube texcwa-996-2 below. Hopefully I dodged the bullet and the car will continue to give me the pleasure it has.
I still plan on sending out for a second oil analysis in at approx 500 miles (as recommended by another Rennlister). I will also be posting the Blackstone Analysis I receive tomorrow if I have any concerns or questions.
At this point, I only have one more question. I noticed while driving the car that my oil pressure would top off at 4.5 bars (never would budge above that to the 5 bar max). I did do a search on this site where others experienced the same thing after installing a new sensor but after time the readings came back to normal. Has anyone else experienced this?
Thanks again to all that participated in this thread and will update if anything changes.
Tex
- Cutting open filter and inspect
- Thoroughly cleaning out sump
- Sending oil sample to Blackstone
- Using a borascope to inspect what I could through bottom of motor
Tex
#109
I dont follow your question.
#111
Have now driven the car on several occasions today and everything else seems normal.
#112
I gotcha now. Your oil pressure is fine above 1 BAR after the oil get to operating temp. Honestly I dont recall, but I think that you not getting to 5 BAR as well is normal as well unless it is cold as hell outside. If it only got to like 3 or 3.5 BARs then I would have concern, but it seems fine at 4.5 or so. 4.5 BAR is like 65 PSI so you are way to the good.
#113
On my car, I think the gauge won't read that high. It "pegs" a couple of needle widths below 5 bar. I am sure the actual pressure is higher then that. When hot, it idles 1.5-2.0 and pegs just below 5 bar at about 4000 rpm
#114
As you can see in my Youtube video, at full operating temp, the low pressure was just below 2 bars and even though I am seeing a difference on the high end, the low end so far is the same (I never ran below 1.75 bars). I know I am just overthinking everything now because of what I found during my oil change. Hopefully I will forget about it as I put the miles on just as I did when I first got the car and was constantly thinking about "IMS" but it sure takes the fun out of driving when these kinds of thoughts are on your mind.
#115
Update #2
Got my oil analysis back and appears to all look good. Again, plan on performing another shortly. Also have now put approx 150 miles on car since closing up and refilling with new DT40, Have driven up to operating temp, running upwards of 6500 rpms and still sounds good and runs smooth. Did I dodge the bullet? only time will tell.
#116
Thanks so much for everyone's comments and help, This question has also been brought up a couple of times, my engine appears to be original, see pic below. I asked my Indy about this and he mentioned that Porsche switched from the hex head bolts to male torque in mid to late 2004.
