Rattling noise coming from rear of vehicle
So I just started noticing this rattling noise when in first and second gears. it occurs at two points in the rpm range. 1,200-1,500 and again at 2,500-3,000 rpm.
I tried doing a search but I couldn't find anything. Thinking its possibly a heat shield or something similar. Any opinions
Well I hear a tinny type of sounding recently developed to the left rear which after the car engine warms up I hear clearer when idling. Seems to speed up as I accelerate then goes away. (unless I don't hear it then because of engine noise). I removed the serpentine belt and pulled and pushed on all pulleys. If anything I seem to be able to get the slightest of movement on the water pump pulley but I would not bet a weeks wages on that finding. The water pump was an OEM replacement pump about 20K back so I doubt it coming from there. I added the low temp thermo along with that job, which I did myself. Sorry I cant help but we could have the same problem.
Check the alternator pulley. I just replaced mine this past weekend and it was seized completely. The car runs normal and my charging is normal but I get the rattle when rpm changes, additional stress on the tensioner which also lead to tensioner pulley bearing wearing out. Replaced both.
