Viezu Tuning
STD is the old correction factors that was in use and some still use them because of the higher numbers produced, SAE is the industry standards now in use by most dyno's and show about 5% lower numbers, not just Dynojet. they can produce their own correction factors but can not compare the numbers with anyone else, which we should never do anyways unless we can produce the exact atmospheric condition for both dyno's.
Are you saying that my numbers are accurate or inaccurate? Just curious
A dyno was used for tuning and it shows the gains here. Doesn't matter what method was used as long as they aren't changing methods between runs to purposely inflate the numbers.
So based on the Dyno Technician's explanation my gains are real. Either way...I recommend the Viezu tune and the dyno process. Hope others can learn and enjoy from this discussion!
HAPPY MOTORING!
HAPPY MOTORING!
They are what that dyno put out, I am not familiar enough with the P-car output to say they are inflated or not.
I purchased the cross pipes. 200 Cel Cross Pipes and FisterD cans sound amazing.
My current exhaust setup:
FisterD: http://fdmotorsports.net/fister-exhaust-996/TG 200 Cel Catshttps://www.topgear.co.uk/porsche-91...ll-sports-cats
TopGear 200 CEL Cats: https://www.topgear.co.uk/porsche-91...ll-sports-cats
Fabspeed Quad tips: http://www.fabspeed.com/porsche-997-...ad-style-tips/
Short Install/startup video: https://drive.google.com/open?id=0Bw...1l0VUVTdk1jMVU
all of the dyno pulls were included in that price? how long did it take them each time to send back the files
never heard of the company but clearly it worked well
I dropped the car off at PreRacing at 9am and picked it up that day at 5. $750 included the cost of the tune, the dyno pulls, and the adjustment of the tune. IMO its a great deal and I am very pleased with the outcome! So far there haven't been any downsides. I put about a 50 miles on the car since the tune. I will keep this post updated if there are negatives.
I dropped the car off at PreRacing at 9am and picked it up that day at 5. $750 included the cost of the tune, the dyno pulls, and the adjustment of the tune. IMO its a great deal and I am very pleased with the outcome! So far there haven't been any downsides. I put about a 50 miles on the car since the tune. I will keep this post updated if there are negatives.never heard of the company but clearly it worked well
However, I would never attempt to tune a vehicle without a wideband installed...the cost of installing an additional o2 sensor is trivial compared to the cost of rebuilding a motor because it leaned out too much during the tuning pulls. Is a wideband necessary when using the Viezu, or does it use the data from the factory sensors?
To answer questions from 5CHN3LL and MoeMonney...I am running a stock pulleys. I did not use a wideband. According to the shop, Viezu uses information from the ECU and dyno.
