clunking: front swaybar bracket smashing subframe
Hey, Rennlisters:
Several weeks ago, I noticed placing load at the front right of the car caused some clunking. I tried looking for any loose suspension parts after removing the front wheels, nothing. After closer inspection, I noticed severe chipping on the front right swaybar bracket. I'd imagine its from all the clunking and subframe smashing. I took it to the shop and they say the car checks out fine. Any of yall out there have any experience with this?
Mods:
Bilstein PSS10s
Front GT3 LCA
GT3 swaybars
GT3 front drop links
Attached aren't the greatest photos, but the chipping is much worse than what is shown.
Any help is appreciated, thanks
Mods:
Bilstein PSS10s
Front GT3 LCA
GT3 swaybars
Caveat, I have no real idea what I am talking about here...
Is that red collar (a Tarrett product maybe?) supposed to prevent the swaybar from moving left to right? It seems like they have too much lateral movement so they can rub. If so, couldn't you just adjust them so they don't make contact with the body?
Don't know why those stops have to be so big. Most stock swaybars just have a raised ledge in the formed metal, not a separate part. All you need is a 1/8" ledge or so, not a huge block of aluminum.
cds72911 and dkraige,
Thanks for chiming in. You're correct, I have Tarret's GT3 sway bar and end links. Are those brackets something I can just adjust and move outwards? Do yall know if this adjustment will affect the alignment?
This won't affect your alignment at all.
I'd check with Tarett on the adjustment. In my simple mind, I'd want them moved inboard as close to the bushing as possible on both sides as it can be without causing damage. This would limit any side to side movement.
Moving them outboard seems like it would increase the "slop" and risk more rubbing on the body shell and other associated noises.
Looks like it can be adjusted with an allen key, and I agree that there is no way you need to worry about alignment changes simply by relocating that collar.
Yeah I may have my "inboard" and "outboard" backwards. I don't know whether these are on the inside or outside of the swaybar bushings. I assumed they were on the inside but that's probably backwards. Point is, move them as close as possible to the bushings so the bar cannot slide laterally.
Sorry y'all. False alarm, shop just found out that the spacer within the right endlink was warped. I appreciate everyone for chiming in. Glad it's behind me now. Thank you all.
