RSS 996 Top Seller | Lightweight Underdrive Crank Pulley # 601 | In Stock
So the pulley is sold for $210 seperately from the belt? And the belt alone costs $30? I just don't see why it's more expensive than the Tune Rs pulley that comes with the belt for less than $200. Am I correct that the belt is sold seperatly?
Have the rss under drive pulley on mine and love it
Made the steering slightly heavier which liked too ;-)
Didn't like that I had to take a dremmel to the engine to get it to fit but it was worth it
Hi Mike, can you please elaborate this? I do not understand. Or do you mean improved efficiency under moderate and higher, near redline rpms? Like on the track.
No offence. I myself have the RSS underdrive pulley installed. But people have to be aware that the underdrive pulley's main purpose is for when tracking the car.
For normal street use one need to be straightforward and honest. The underdrive pulley is detrimental for the cooling efficiency at the moment the M96/97 engine is needing it most!
At low/idle rpm the water pumping capacity of the waterpump is not efficient at all. With the underdrive pulley the water pump will rotate even less under these circumstances.
When coming to a standstill after a drive (which is most common in non-track conditions). the driving wind falls away, the thermostat is most probably not fully open and the water pump is not moving a lot of water. It is at these moments the engine still needs to get rid of a lot of heat. Haveing the underdrive pulley is not improving the cooling efficiency at this moment when it our engines needs it most. The probablilty of local hot spots increases and we all know what effect these have on the damage it can cause.
Silk, thank you for your input - That was a concern of mine, and the very reason why I never installed one, I do tracking events a few times a year, as both my 996's are my daily driver. Thanks again!
Just don't let the car sit and idle and you've got nothing to worry about...
Mike,
I'd like a discount code if still available, I could use one of these.
Thanks,
Mike
Thanks,
Mike
Link above doesn't work.
I will update link, Old website, We transitioned to a much improved user friendly platform earlier this year! There is also a direct link to homepage in my signature below.
See direct Link to 601 Pulley and Belt:
http://roadsportsupply.com/search.php?search_query=601§ion=product
