need help sorting out headlight issue please
i have an 03 turbo and I've had an issue with the head lights for some time.
my car came up to canada from the united states, so it had to get a relay installed for the DRL.
so intermittently head light goes off, when going over a bump but then when i try to turn it back on it will just flicker....or it will go on but the other head light will go off....wierd...
I've check all connections, and all is good, i thought it had something to do with the DRL relay so i eliminated it, and did nothing.
i don't want to start throwing parts at it as the blasts are quite expensive
any help would be greatly appreciated
thank you
thank you
Have you changed out your ignition or headlight switches lately, both are known for causing "electrical" issues. Ignition switch is pretty easy, I have not tried the light switch yet.
http://www.pelicanparts.com/techarti...eplacement.htm
http://www.pelicanparts.com/techarti...ering_Lock.htm
