litronics in place of stock halogen 99 996?
I have been searching but not coming up with a positive answer.
I have found a set of litronics
but can't decide what is involved with converting to them
I seem to find things saying you can just bolt the litronics into my 99 996 c2 that currently has the stock halogens (I'm wanting to replace the orange lens headlights)
But then I also am finding things saying I need another wiring harness... it seems maybe I can bolt them in, but they will function more like a regular light, although still brighter and clearer then my stock ones. But that without an extra wiring harness the high and low beams won't "combine" when on high for even extra brightness?
Then I saw mention of possibly needing to replace the headlight fuse with something bigger (although then I again wonder if the wiring is up to that)
Thanks for the help
Thanks for the help
You dont need a harness. Just take out your old lights and install the litronics. Then adjust the height with the headlight adjustment tool from your tool kit and youre set. If you use the harness and module you will have high beam HID lights also but its not necesarry.
Yep, I personally learned the value of the Porsche OEM tool kit when one of my litronics got out of alignment. The adjustment tools feeds into a channel to adjust the position of the projector lens. Without that adjustment, I would be blinding people at night. Before I fixed it, people were turnin' on their brights to alert me... and flashing the lights and all. hahaha.
Actually, you have to switch pins 4 and 5 around in the original wiring harness if I remember correctly. (I would have to dig around to remember) So, it's not plug and play but you dont need a new harness as you can alter the old one and of course the ride height leveling portion won't work in your car.
You can find an allen wrench long enough to adjust the lights I believe.
Agreed. They are plug n play. The only functionality you lose is the auto-leveling that the factory Litronic cars have.
well, the set i had committed to buying, fell through... but it is still good knowledge to have if i come across another set that doesnt cost more then half the other cars i own lol
I appreciate the responses!
