Will a 986 Boxster 2.5/2.7 crankshaft work in a 996 3.4 engine?
Pardon my ignorance but will a Boxster 2.5/2.7 crankshaft work in 996 3.4 engine?
These crankshafts are much cheaper and seem to be identical.
Thanks for your the help!
Just check the part number when buying a replacement some are interchangeable , if the part number matches your in business, look on the crank there are a few numbers on there but it's the one starting 996 ok
The 986 2.5/2.7 crankshaft starts with 996. Thanks why im asking. Ive received various responses.
Received 1,091 Likes
996 Crankshaft http://www.autoatlanta.com/porsche-p...section=102-00
986 Crankshaft http://www.autoatlanta.com/porsche-p...section=102-00
You need the same IMS drive gear design from a similar year, what year is your engine?
I found the solution. The 2.7 and 3.2 crank from the boxster 986 works with the 3.4 996 engine. Got a perfect polished crank ready to use for $600.
Thanks for for everyone's help.
