993 Turbo Forum 1995-1998
Largest intercooler that'll fit under a GT2 wing?
Old 03-15-2017, 01:18 PM
Don Nguyen
Don Nguyen's Avatar
Default Largest intercooler that'll fit under a GT2 wing?
Anyone have a GT2 wing know what the max size intercooler you'd be able to fit underneath that wing?
Thanks!
-Don
Old 03-15-2017, 05:48 PM
racer959
racer959's Avatar
This is a Protomotive intercooler that fits under my stock turbo wing. I just had to notch a section in the right hand corner.
Old 03-16-2017, 03:08 AM
Basal Skull
Basal Skull's Avatar
There aren't many larger intercoolers that people have tested here that are actually more effective than stock. Some of us have made our own (I hacked together 2X 997.2 gt2rs units) that seemed to work pretty well. Tracker made one out of 3 x of the same cores and got it to fit using na throttle body. The secan intercoolers were used on gt2 race cars (also with a custom intake) but I think you needed a gt2 wing. If you can find an Andial intercooler, it will fit under the stock wing and are very efficient. So much so that I have them on my car currently instead of the unit I built (which are also pretty good). If you search for some of my intercooler threads, there's a bunch of data logs/graphs.
Old 03-19-2017, 02:04 PM
tacker
tacker's Avatar
IIRC, 28"x 14" allows enough room for air box and to reach back to disconnect. I use 3 gt3 rs cores and made custom carbon airbox. I no longer run the fans. Setup works great. I have more pics if interested
https://rennlist.com/forums/993-turb...r-build-4.html
Quick Reply: Largest intercooler that'll fit under a GT2 wing?
