Ruf Suspension Installed
Jim, the dinner offer applies to a ride in a 3.8. If you have secretly acquired one, email me with the restaurant name and a convenient date and time!
SYF: Remember, that statement generally applies when the 993TT is using 100 octane (or has dual plugs). The centrally-mounted spark plug in the 996 does much better with the 91 octane we have in California.
hey I thought I would mention that I found it weird that they put the sway bar mount all the way at the bottom. It would give maximium preload and make the bar effectively that much stiffer. Every other setup with pss9's that I have seen usually puts that mount about midway from the bottom of the threads and the bottom pearch.
wow you don't understand preload then. If you are setting the mounting point lower on the strut, then it is effectively increasing the drop link or the length of the bar arm and hence preload from 0 load. It has nothing to do with variance between the two. It has to do with the effective preload it gives.
btw I am not trying to be a jerk just being lazy without measuring the static height of the old drop links and mounting points and comparing that to the new drop links to determine the proper height of the adjustable mounting point on the strut.
I think Bob is right, preload is load applied before you start moving the suspension. The sway bar would be twisted as it sits static if it's preloaded. I think what you are talking about would be changing the leverage by moving the fulcrum of the lever.
SPR,
Preload is a measure of load or 'TWIST' on the bar in the static position. I do not have time for a full geometry lesson at the moment, but the drop links are at roughly a right angle to the bar. So the only thing that matters is how far out on the sway bar arm you attach the drop links. The length of these drop links has no bearing on the force applied to the bar. If someone pushed the end of a 36" baseball bat into your chest with 200 lbs of force, how would it be different than another person pushing a 10" stick into your chest with 200 lbs of force. The ultimate force to your chest is 200 lbs. The length of the rod applying the force doesn't matter. Same exact thing on the sway bar with the drop links.
So take measurements and put it where you want to on the strut as it won't matter. As long as when the car is sitting with the suspension under load and you can take a bolt out of the drop link easily and reinsert it, then you have no preload.
No I am familiar, but I was just looking at it as being more precise from the stand point of the heights from side to side and making sure they are exact, hence no preload. I think we are both saying the same thing but interpreted initially differently. It just seemed like no one takes the time to measure exactly the distances to make sure to a tenth or so that they are exact compared to each side
btw I do like the thought of having it as low as possible to make sure there is no binding issue with the lower control arm, just as long as it doesn't scrape on anything when going over speedbumps or driveways
