got to use my fire extinguisher...
Mike, that is quite a trip for you from the main land. I bet there are few here that will ever have the experience of driving their cars through an area as beautiful area as Cathedral Grove. I was last in that area in the 70's and the Airport was Michigan road rough back then. Outside of the car's shock and driver's teeth damage that sounds like it was a terrific event at a fabulous location.
Rick
Rick
Rick - Heard that the Cowichan track is supposed to be ready in Sep this year (but would assume maybe next Sep!). I'm already looking at ways to get on the ferry with my lowered car, I understand you can request the bottom level with the trucks that is easier to board.. (Mike I guess you didn't have any trouble getting on the ferry?).
Richard - I think you gain a few hp and lose some weight if you delete the hydraulics! I was running for a while with just the belt taken off (but all the plumbing intact so it would be easy to return to stock) but now the plumbing/reservoir has been removed - and an extra fuel pump in it's place!.
I think the Ferry guys enjoy seeing these high end cars scrape their way out. I also have a FPB, that helps.
Cheers,
Mike
Got me few of these, one for each of my ‘fun’ cars and one to replace/add to the one in the kitchen. It’s also a weight loss maneuver, as you can see, I’ve lost 2.8kg (+6lbs!)...
they’re really compact so fits fine in a glove box.
