Engine decklid strut replacement
Just purchased replacement struts from sunset. Did a search looking for a how-to or comments on difficulty on doing this. Didn't see anything but I know there must be something. Can anyone help? Thanks
steve
steve
Had to find the pic of when I did the PS line. Pretty simple. Just have to take crap out so you can access it. Of coarse the intercooler, then the Air box, MAF on pass side and blower motor and ducts on driver side. 2 clips on each end of each strut. Just DO NOT DROP ANYTHING!
It is possible to replace the driver side without removing the blower as I didn't want to tackle that at the time as it was my first change to the car when I got it. I have since discovered that removing the blower is as easy or easier than removing the air box.
The clips are easy to drop so it is a good idea to line the area below the hinge in case it falls out. Otherwise it's a pretty easy fix.
Good luck, the results are awesome.
Yah, I usually use a large cloth below the end of the strut in case you end up slipping and dropping a pin or clip. Remember how the shock was oriented before you take them out, or do one at a time (better).
Cheers,
Mike
Cheers,
Mike
I got the tip from somewhere on here to use fishing line on the clips either for reinstall or removal. if you can thread the line through and give enough length even if it goes flying you still have it. I also did the towel beneath deal. I think this was one of the first DIY's I did on the car besides oil change. the Frunk ones are worse. =-)
I replaced both at the same time. If I had to do it again I would have only replaced one of them as the force of the new shocks is really strong. I have to hold the tail down as I pull the release handle or it will fly up.
Make sense?
Not a bad way to approach it. Less work with functionality. Mine does pop up well, but it sticks in the latch when I pull the release. So I have to give it a bit of a lift for it to go up. When it does it does it with gusto.
I always thought it was the rubber guides on the left and the right that rub against rub strips on either side. I don't think they are adjustable so it might be the alignment of my lid that is causing it. I like it that way so I haven't investigated any further.
Good luck, just take it slowly and don't do it on a day you keep dropping your keys.
Make sure you have the correct shocks - the cab shock are stronger and will make the deck lid fly up - and that is an issue long term banging away at the hinge stops ...
