solenoid exhaust control
fabricating the pipes for this job won't be a problem, finding the space to duct exhaust directly out will be tough. instead of ducting out of the tail pipes, i might duct it down and out instead... may not look so pretty but will do the job.
Alternatively a "y" shaped joint with a solenoid controlled trap door might work beautifully?
maybe?...
insane enough ?
as along as the wastegates are the "path of less resistance", the exhaust will flow out through them easily.
Trapdoors are bulky and always leak
hence the wastegate idea...
You have another email
SpeedArt makes solenoid-driven auspuff for 996.
996 Sport-Auspuff mit Resonanzklappen
996 sport exhaust, at 5000rpm autom opens bypass to straight through exhaust .
http://www.speedart.de/
Heres a pic of one of the setups I was talking about that might add fuel to the inspiration for your little project. You can see how the e-cutout is set up.
This civic hatchback just dyno'd 497hp to the ground yesterday .
what if?
i made a center exit exhaust?
princeton, got any under car pics of your set up?
you think it would fit with cats on?
how bout this?
how bout this?
