Oil change / cleanup, now little boost
#31
I'd continue to use the old hoses, why fix something that's not broke. I know I'm probably in the minority when I say that I liked the original old non orange tipped ones better - I just thought they fit better and the clamps didn't cut into them like they do on the orange ones..
#32
Oh and just carry your new ones in the frunk as a spare and don't leave them on your shelf. (My usable spare was my old black ones, the oranges ones I couldn't reuse - In addition to the relay/few fuses/belts) ask me how I know..
#33
I do use Breeze clamps on the top though - have not gotten around to putting them on the bottom near the turbos, since I think some sheet metal work would be required to fit them.
Cheers,
Mike
#34
You certainly are not alone - the original hoses work just fine for me as well, the same for a few other Turbos around here. Sometime people just gotta have the new stuff, and I will replace the hoses when it's time - but they are in good shape so it's not time yet. I have a bit of fraying on the top of the right one, but its not an issue.
Cheers,
Mike
Cheers,
Mike
Tried a few attempts atmaking my own out of aluminum tubing. Would've worked if I could get them in. Need a little play to squeeze them in. Engine out would've been possible.
#35
I did order the new updated hoses, but I have to tell you that now that I have my old hoses dialed in I see no need to swap them out. Boost comes on early 3200-3600 and stay at full boost until I shift. At least in 3rd gear, bit harder to keep my eye on the boost gauge in 4th. Still haven't done High Speed boost pull in 5th or 6th gear.
I will install my Breeze Clamps, if I find I need to trim the tin at the turbo end then the old ones will go back on. I think the OEM hose on the passenger side is a about 1/4-3/8" short on the turbo end. If it was a bit longer I could get the upper end to sit just right at the intercooler end and have plenty of overlap to put the Breeze clamp on. As it sits now the intercooler side the hose has a bit of tension on it sit just right and there really isn't a great amount of overlap on the turbo.
If the updated hoses are a bit longer then I will definitely install the new ones.
I have already got a DME relay, now spare hoses, maybe some spare Breeze Clamps for the turbo end. Now to put a tool kit/parts kit together. I was very impressed with Mike J and what he had with him when he became the de-facto local mechanic at 2013 993 FEST. I think I may get close to copying him except for his wisdom but I'm working on that.
#36
Now the S Car Go ones are nice, I don't feel I need to carry a spare with those!
#37
