My 993TT has arrived!
Busted! Someone didn't read my thread and everyone else did......your standing in the line to the left and everyone else is in the right line.....
I already mentioned it in my post above but yes, it is being scoped and quoted and will be bagged and tagged very soon...
You mentioned it, I said no one else mentioned it. semantics my good man.
What are you thinking about putting on the car? there seems to only 3 suspects
Ahh...I'm busted it seems.
Well, I priced out HD/M030 at $1800 or PSS10s at $2800. My local Indy will install, ride height and corner balance for $1200.
So I'm thinking PSS10 for sure...
If you have the means, the install really isn't that bad, did mine and it was a good bonding time. $1200 is a good deal with balance though, I think I paid ~500 for the alignment/balance on its own.
rob
Thanks guys, very kind of you. I've been driving her non-stop since it arrived and just having a blast. Did a medium speed cruise at night tonight, windows down and sunroof open. Wow!
See you soon at CnC! The Yellow beast left my garage today so its 100% Turbo now.
I believe you but this seems odd. Can't you adjust the softness of the ride. Are your settings different or the same and while the same is one is harsher than the other..?
Congratulations, I have PSS10s + RS sway bars and drop links on my TT- as Julia Roberts said, "corners like its on rails" - no flotation possible. Your install quotes are about the same as mine were 2 yrs ago. Td
