Thermostat issue? Oil temp gauge only goes to 8:00 position
Not sure if this is an issue. Runs fine, kept rpm's low for the first 10km. After 90 minutes of driving mountain and highway roads, gauge just now reads about 8-8:30. Thought a faulty thermostat? 20C outside
Appreciate your experience with this.
How many oil coolers do you have? there could be an extra one installed on drivers (left) side. You can check the oil lines under the car to see how hot they are. if you have a point and shoot thermometer you can get it from the front grill to see how hot the oil is.
Good ideas. Seems to run fine, I've not had it through our so called winter here before. In warmer weather, goes up to about 9:00 which everyone seems to say is normal. Later short runs today, it warmed up pretty fast and oil lines were warm. I'll keep an eye on it.
Thanks for the suggestions.
