Blowing smoke on start up! HELP please
read Kevins sticky at the top of our forum titled have your turbos failed
good luck, it appears to be nothing major other than a pain in the neck.
So....Parnelli, I recently had this problem also. Started out of the blue after no problems for the few years I have owned the car. Also had not done anything with mine in the months before it started smoking. I took mine to Matthew at Mortor Werks Racing, a porsche exclusive shop in the ATL area. Great guys and seem to do great work. He put the Turbo Craft check valves and oil lines on my car. I told him about the Mahle vs Porsche filter talk on Rennlist (even sent the thread to him) He insisted that he has never had problems with Mahle and uses them on all the racing engines (including turbos). I chose to trust his judgement and so far no issues. We'll see what happens in the long-term.
I have a theory - and I think Kevin shared it with me. These problems creep up in the spring, when the weather warms up. Could it be that since our cars hold so much oil, the oil expands enough due to the outdoor temps to make it over full? Whereas, in the winter, it was just right?
I understand that when the engine is warm, all of that goes out the window. But the combination of warmer out door temps, oil expansion, and car sitting for a while could cause the oil to seep into the turbos.
Ever notice that the turbo leak problems start in the spring? Mine did last year. Just a thought.
Your issue sounds exactly like what I am dealing with. I am confused, though. What exactly did they did they do to stop the smoking? What was the $$ cost of fixing it? Did u drive it to them or have it towed? Thx
@ca993twin: My mechanic was working on the Porsche LeMans cars for porsche motorsport in germany in the 90s. He remembers that oil was frequenlty dripping out of the turbines when the car was in storage and that they lifted the car higher on the back to avoid it.
andreas
andreas
The oil line check valves will hide the problem with the Mahle filters. They are an excellent idea, but so is NOT using Mahle on a TT. Do their racing turbos also use the check valves? Note that the shop uses Mahle filters, and you had the problem before they installed the check valves. I've seen way too much evidence on my own. Mahle doesn't work right on a TT.
Good luck with yours, Parnelli.
You guys are foolish allowing ANY race shop or indy for installing the Mahle (Mann, Bosch, Fram or XYZ) vs the factory Genuine Porsche filter.
Here is the problem>> buy the time you catch the oil filter problem, your turbochargers are soaked with oil. You are driving the car burning the oil which is getting cooked in the heat shield and is wearing out your turbine side sealing rings. Your turbochargers are going from a "good" status to a "WORN" status when this issue is present. The secondary effect is BURNT and UNBURNT oil flowing into your CATS. Plugging the cats> sucking the life out of them and eventually putting all the backpressure on you exhaust valves/combustion chamber.
With that said, if you have a shop that is too lazy to install Porsche filters, do the oil change yourself or take the car to another shop or Porsche dealer. If you take the car to a Porsche dealer >>be careful most will fill the engine with 0w40 engine oil which is too thin for the air-cooled engine. The piston to cylinder clearance is to large for the 0W.
Lastly, every car that has suffered this FATE needs to have a engine leakdown done. Every month I get the call about a failing 993TT, to find out that it really needs a topend overhaul. At 15% leakdown the turbochargers will push oil..
OK guys, I did some digging in my files. I've had 3 oil changes in the 3 years that I've owned the car. The first two (done in 2009 and 2010) had an oil filter with part number 993-207-201-02. Last year (2011) the part number was changed to 993-107-203-03 but the invoice does not say if it was a Porsche filter or Mahle filter.
This sight below lists the SAME part number for both oil filters but the one that ends with 'OEM' is a Porsche part and the one that ends with 'M67' is a Mahle oil filter
http://www.pelicanparts.com/catalog/...ENGoil_pg1.htm
Since my invoice does not list the last 3 digits and does not specifically say Porsche or Mahle, I do not know which they used. I've left a voicemail for my service rep at the Porsche dealership that did the work. I'll know more tomorrow when he calls back. Can a difference in oil fliter manufacturer really make THAT much of a difference?
There are check valves in the filters. There were (are) problems with the Mahle check valves. ther is a $10 cost difference so why risk it?
Sunset is likely the best source for OEM.
I would be surprised if your dealer used anything other than Poesche branded filters.
