value of 993tt hollow spokes?
I have a set of hollow spokes from a 993 tt with the 10" rear wheel, not 11". They are powder coated black. Rears have some curb scuff touched up with black paint. Fronts are nice with no issues. What is the current value of the wheels? I need to make room and have put a different set of wheels on my car.
Not bent. Had them check when the tires were removed. Great for track or refinish back to OEM color. I don't plan to use them anytime soon so shoot me an offer if interested.
I can answer some of that .. yes and the offset is really perfect for filling in the wheel arch .. I actually run 5mm spacers with them for a little more 'push' outboard .. the actual width of the wheel is just a tad over 10.5" not a true 11" wheel width .. edit: IMHO, the rears need a 295/30 tire .. the 285's stretch the sidewall inward enough that I decided to go up a size .. I know for some people it wouldn't matter and although Tire Rack says it's not good, many other tire people say it's fine.
Oh .. and although many tire people say running the 285/30 width tires are ok, I found that the sidewall does pull inward quite a bit .. so I went up to 295/30 ...
The 996 Twists are only 8.0 up front, and I hope I can still run the 235/40's up there and not the OEM size of 225/40. Can I?
