993TT Power Steering and Brake Upgrades
My 993TT power steering upgrade courtesy of Rennline pedals and brake upgrade courtesy of Paul Faieta of Protosport in NJ-997GT3RSR Cup brakes fit to 996GT2 front wheels and 996Turbo rear wheels:
Wow. Great car, BIG brakes.
Are the brakes for the track or just to match big stopping with the big HP?
How much fabrication was required? I recall Simon "Full Boost" put Cup brakes on his GT2 replica and he spoke of significant unique fabrication for the fronts.
I ran this new setup at the Glen the last two weekends, and they were solid with GT3 brake ducts we also added to the 993TTS factory ducts, with no hint of wear or heat effects.
AFAIK, no special fabrication was needed to fit the brakes in front-our only obstacle was that the factory hollow 996Turbo twist wheels I use on the car did not clear the large front calipers, so I am using 996GT2 front rims (solid spoke wheels have an ever so slightly larger inside diameter versus the hollow spokes).
Also, are those factory 997 Cup rotors? Maybe that explains the calipers are 996 GT2 front and 996 Turbo rears to match the rotor sizes and offsets?
I am keen to upgrade the brakes on my 993 Turbo (now GT2-ish) without a lot of trial and error.
Also, I don't see any reference to the "power steering upgrade." Did you swap to a 993 manual rack? (that's something else I have planned.)
Stock 993TT rims do not have sufficient internal diameter to "clear" the larger front caliper. I assume that the GT2 rims do. Hence the change. This would be my interpretation.
As stated above, actually, I haven't used the 993TT factory Turbo Twist wheels since I upgraded the car with Protosport, and if anybody wants to purchase them from me, feel free to PM me.
Sorry for the confusion Carrera GT, yes, the brakes are the Porsche 997GT3RSR Cup car brakes made by Brembo-they recommended them when the Brembo Clubsport brakes they supplied couldn't handle the thrashing at the Glen. They are the Cup car brake rotors/hats/calipers/pads/fluids.
They are NOT the 996GT2/Turbo calipers (the 996GT2 and 996Turbo references are to the wheels-which BTW I use without changing the offsets) but the Cup car calipers which in front are indeed huge.
The 993TT "power steering" upgrade was sarcasm-I simply modded the throttle pedal from Rennline for easier heel-toe action, and since we can "throttle steer" the car, well, with 650-700HP on tap....
Correct, the wheels are 996GT2 fronts which have a slightly larger internal diameter versus the 996TurboTwist fronts (the wheels I had been using since the power upgrade) which are hollow-spoke and thus "thicker" (with a relatively smaller internal diameter even though they are both 18" wheels) versus the 996GT2 wheels which are solid-spoke, so the 996GT2 front wheels can clear the large 997GT3RSR Cup car calipers whereas the 996Turbo wheels could not. Since the Cup car rear calipers are relatively small, I can still fit the 996Turbo rear wheels without issue.
I noticed your pics thread and it took me a while to go searching and do a CPR thread revival on this brakes topic -- how are those brakes holding up? Assuming no problems, I'd like to do the same upgrade, so if it's reasonably convenient, please post whatever part numbers and tips on the install. Hopefully it doesn't require major surgery, just a spacer block and some brake lines. I'm always the optimist when it comes to these things. I'll DIY it, and I expect I'll need to figure out replacement wheels to clear the front calipers. I'm hoping I can source a one-piece forged wheel in 18's.
I order the replacement rotors from Brembo, but the rest of the hardware is unchanged since the new setup. Don't ask about price.
You will have to ask Brembo about availability of the conversion since I got the setup through Protosport as I didn't contact Brembo directly, and I don't know if any other hardware is needed for the conversion. Hope this helps.
The brakes have been excellent, no fade, no pedal loss (using Castrol SRF), the rotors last an entire season of track use (15-20 days), I use Hawk pads (DTC-60's up front, DTC-30's in back per Brembo's recommendation for medium pad hardness), albeit I do go through 3 sets of front pads a season.
Surely the friction disk isn't too expensive?
I've seen kit prices on the 6 pot fronts (about $4000 with rotors) and not much cheaper for the four pot rears (crazy money compared to much more complex Brembo hardware targeting Vettes, but there's Porsche tax.)
Hawks instead of Pagid is surprising. Wear is on the high side, but stopping 3000lbs+ of 700hp makes for ferocious heat equations. A similar setup with PFCs on the 997 RS seems to be less expensive all round. I wonder if PFC makes something for "old" cars like the 993 ... : )
One thing I remember about the Brembo GT caliper/rotor with Pagids running slicks was the "halt the rotation of the Earth" performance.
I guess I'll compare with Endless and Performance Friction and see what's new, but if I can justify the cost, those Brembos are still the most impressive thing I've seen on a 993.
