Best Porsche tuner in North America?
#31
I'm not sure. My take is that the european tuners are not freqently discussed here (apart from RUF). In Germany there are also many small firms which have great knowledge of stuff like this. RUF needless to say but there are also firms which have former RUF personel working for them. One example is RS Tuning which is led by Mr.Reinhold Schmirler, former RUF Employee. RS Tuning is top notch. In Germany furthermore you have Manthey ofcourse and Techart, Gemballa(?), Roock, Strosek etc. but also smaller firms like SHK Sportec. Then you have Sportec in Switzerland, JZ Machtech, Fearnsport, 9M etc. from UK. Then the Scandinavians with Autotuning (RUF) in Norway and Speizialmotorer, GT Motorsport among others in Sweden. Really too many to cover here, each with their own special competence of course.
It seems to me the market is always asking for a vendor capable of delivering a complete, known quantity power kit to take the 993 Turbo engine up to the reliable limits of its stock internals (say 500-520 hp and lb-ft.) Going above about 520hp leaves behind any notion of bang for the buck and introduces a very real risk of just plain "bang!" Then again, if a vendor offered a robust engine rebuild and took the engine to its thermal limits (say 750hp in very round numbers) and put a price and a warranty on that kit, I think there's demand out there for that kind of car, too.) So it will be interesting to see how this "America's Top Tuner" thread unfolds. : )
#32
OK I see. What about Jochen Rohr? On their homepage his cars are all over the place .
When I did my due diligence before I noticed that FVD has quite a few "power kits" for the 993TT. Does Andial use these parts when they build their engines? I was just curious since they seem to be in close contact with eachother.
Btw, how are your winter projects coming along?
Winter project's almost done.
#33
Of US tuners using European support? I don't think there is any benefit to disclosing names of US tuners, suffice to say some of the names could be shocking. I personally see it as a good practice to share areas of expertise, no one knows everything.
Same that a few European engine builders use a lot of US developped and tested parts.
RUF does not do their own tuning, neither does Manthey, Gemballa, Techart or Cargraphic It does not change anything in the quality of the product they sell.
#34
^^ As an FYI Jean, Manthey used to do this in-house, using a guy named Ansgar Wiesen. He's now out on his own in DE. He remapped my PMS 450hp ecu a few years ago. i was looking specifically to reduce the inherent K24 turbo lag and pick up a few more hp than what came with the rather conservative PMS mapping. He did an excellent job for me and the car hit virtually the same speed as Felix's at a vmax event later that year. We logged the IAT's on both cars that day using Felix's thingymajig and mine ran substantially cooler on the same fuel. From searching here, looks like he's still in business on both the air and water cooled sides.
#35
Brian you are spot on. Ansgar is a excellent tuner, he has been a freelancer for Manthey and several others for many years..In fact I dont think he ever worked for them. He now owns the shop where he used to work, the previous owner is very reputed in Germany and was Ansgar's mentor. I had a chance to check out a durametric reading from one of his tunes on a wild engine and he does brilliant job at controlling all the parameters under an ECU controlled boost setup.
#36
Viggo,
I visited Andial in CA last March 2010 and has some good dialogs with Dieter et al, they were willing to do the full monty on my TT, with 3.8, GT turbo's etc etc, at the end of the day and following a detailed quotation it would have cost 50K and ~ 3months, plus shipping across the continent from Quebec.
As you know, I decided to go with Todd at Protomotive, where the first shop (a "stinker" and will remain unnamed) totally messed up the install/tuning, I ended up shipping the car to Protosport in NJ and it was then looked after properly and professionally.
Summary, John and Paul at Protosport know their air cooled 993's and I would highly recommend them in conjunction with Todd's knowldege and kits.
Derek
Derek
#37
Pic below of the two distributors.
#38
blackie came to me with the fvd unit installed. Jimmy's suggestion was to run that one until I got comfortable with the performance increase over the RUF, which was substantial according to my butt dyno. I ended up running it all last season, as I was also making additional changes to the car. The Thielert unit is in the car now and just needs me to be back in NY (and Monticello to be open) to try in out.
#39
Former Vendor
If it were my money, I would trust a company like Andial to build my stuff. I am sure if you went in with a stack of cash and said "ENGINE NOW", they would do it for you.
lol.
lol.
#40
The above is somewhat a myth
The vast majority of other tuners/engine builders also stick to Porsche parts (rather OEM to be more accurate) for tunes up to 500-520 bhp, just like Andial. The trick is what happens beyond those levels.
But even at ~520bhp levels, Andial uses non OEM parts, to name a few, Carillo rods, aftermarket exhaust, even the Mahle 102mm P&C do not have a Porsche part number (different from the 993 N/A 3.8 ltr) , the sealing rings, the intercooler I think, the ignition splitter, and let alone the brain itself!
To go back on topic somewhat, I can comfortably say that there are many many engine builders out there in the US who can build just the same quality build and achieve the same performance as Andial for half the money.
Andial's reputation is excellent and I am a big admirer of their racing days, I would sleep comfortably at night knowing that they stand behind their product, but at that price, all others do as well.
The options are many for non-bespoke builds.
#41
... Andial uses non OEM parts, to name a few, Carillo rods, aftermarket exhaust, even the Mahle 102mm P&C do not have a Porsche part number (different from the 993 N/A 3.8 ltr) , the sealing rings, the intercooler I think, the ignition splitter, and let alone the brain itself!
#43
Viggo,
Derek
Derek
Andial fans might not like this...
But I get your point and I agree that Andial has a great reputation. Someone like Todd Knighton could also build a twin plug 3.8 monster engine, probably for less than 50K.. Probably better value for the money. The resale value though would probably be higher with Andial but it's tough to anticipate.
What do you mean by non-bespoke builds? Just curious..
Does anyone know how the 964 turbo (3.3 & 3.6) is as a donor engine for a high hp build compared to the 993 turbo engine? I've heard that the engine case is very strong but of course it doesn't have the twin turbo setup.
#44
Hi Jean, thanks for the informative post. I also understand that when you get past 500hp you have to look at other rods and bits and pieces. DRPM mentioned above that he got quoted 50K USD for a Andial twin plug 3.8 engine I guess similar (?) to what BB has in Blackie. Of course it's a lot of money but I don't think it's really that expensive. Needless to say, I payed a lot for the turboR conversion..
You raised a very good point on value... There is not much value left in such an engine after a few years, as they need to be rebuilt
Here is my take on the value issue...
I got a 48k usd quote from Andial about 7 years ago for a 3.8 ltr twin plug for 570-6xx bhp. They kept a single stock fuel pump (limit ~520bhp), stock valve springs, stock hydraulic lifters, the stock injectors (limit ~520bhp), stock oil pump, aftermarket exhaust system, stock headers, K16/24 turbos (limit low 500s bhp) they upgrade the IC, and currently, they give you an FVD program ( it used to be only the Thielert back then)
The above is a low 500s bhp setup. To support this, the performance we have measured is in sync with these HP figures. So the qestion to ask is why not stick to a rebuilt 3.6 ltr single plug, and stock intercooler for such power levels, and get an off the shelf FVD ECU? Savings would be huge.
For the same $50k usd, other builders use the exact same internal components (Carillo, Mahle, etc..) + upgrade the valve springs, GT2 cams, GT3 oil pump, twin Bosch Motorsport fuel pumps, custom headers and exhaust, 60lbs injectors, larger turbochargers + custom intercooler .. Reliability is the same, and performance is much better..
I would go any day with Andial, but also with a number of other builders and get a superior engine. FInding a good builder is not difficult, there are many experts on the forum itself among the sponsors and other, however the programming and tuning part are the tricky bit and worth paying a premium for when choosing a tuner, be it in the US or Europe, it is the same story.
