A little help please. Doing EVO uprights and....
I discovered both front drive shafts have the rubber boots ripped open and lost most of the grease. I removed passenger side drive shaft but I cannot see how to separate the big bulky housing at either end so I can slide new rubber boots.
Anybody
Anybody
Thanks for the cheering guys!
I did more research and turns out I have to remove the end cap that bolted to the front differential (looks like a metal derby hat). This cap is pried off, then a circlip is taken off. Finally, the guts are taken out and you can replace both rubber boots.
thanks.
thanks.
