New owner impressions
#32
I don't remember off hand. They were the factory mount for a 996 TTs. They gotta be at least 4 years old.
I'm guessing your suggesting replacement?
#33
Regarding the exhaust most folks with run a muffler bypass which takes about 50# of weight off the rear, improves spool, and increases sound without getting the pesky CEL. I run cat bypasses and have unpacked my factory mufflers (they are a straight-thru design anyway) and have been very pleased with the tonal qualities.
#34
ok, so new tires up front. Thats no biggie.
I have fabspeed muffler bypasses on the car. Its still very quiet.
which cat bypasses do you have? fabspeed? Seems a bit pricey for what they are, no?
Thanks.
Thanks.
#35
Yeah I have the Fabspeed. The don't fit very well either. Fabspeed has a new modular exhaust with bypasses that looks better but still it is alot of $$ since your car with lose HVAC heat by using just straight pipes.
#37
Regarding the sound, if you are looking for louder at WOT, it is tough with turbo charged cars as the turbos themselves are rather good, too good, of mufflers...
If you have stock cats, then you may switch to 100 cell cats (not CEL that way vs cat bypasses).
#38
The nice thing is that the HTRZ-III are rather inexpensive, so, yeah, replace the fronts so you have matching tires.
I have the HTRZ-III's on my Boxster and am very happy with them. Not quite as much grip as the pricier tires recommended for our cars, but very close. I will be using them on the Turbo when the current set of Michelins wear out.
#39
I think part of what I'm feeling are the characteristics of an AWD car. you simply need to drive ti different. With the mustang (which had 275s up front, and 315s in back), you could slow it down, then blast on it on the way out and it had so much tire that it just stuck pretty well.
#41
However, after going with solid suspension bushings recently on the 993, it is oh so close to the feel of the Elise. Still, the Elise reigns supreme in the one-with-god handling realm.
