Cam Carrier for 993TT
Turns out I need a new right side cam carrier and having checked the PET catalogue there is a different part number for the Turbo (993 105 012 50) compared to the 993 N/A.
Bearing in mind that people seem to swap cams between the various different models of 911 as mods I was wondering if anyone knows what the difference is or has a couple laying around their shop that they could compare for me as it will be a lot easier to source a N/A one than the turbo and OPC want a small fortune for a new one.
Andrew.
I know that RUF Dallas is doing a Turbo R conversion on a 993 TT now. Part of the upgrade is new RUF cams. If you are trying to source some used TT cams, you might want to give them a call.
Internal oil passages are slighty redirected in order to compensate for turbo oil supply., at the end of the housing (both ends) there are some steel ***** about 9 1/2 mm size inserted for this purpose, I have used the N/A version on TT without no ill effects that I know of.,cheers.
OTE=Andrew 996TTS;6975714]Turns out I need a new right side cam carrier and having checked the PET catalogue there is a different part number for the Turbo (993 105 012 50) compared to the 993 N/A.
Thanks[/QUOTE]
Thanks[/QUOTE]
