993 Turbo Forum 1995-1998
2 weeks left until track season starts, figured it was time put the fatty on a diet
Old 03-24-2009, 04:40 PM
NoSubEDU
NoSubEDU's Avatar
Originally Posted by wagongotya
Come to think of it i think just the fronts up by the oil coolers is removed, the rear section is still intact...
Same here.
Old 03-24-2009, 06:28 PM
DM993tt
DM993tt's Avatar
Originally Posted by NoSubEDU
Nice! I run 245/40 in the front and 295/35's in the rear but may try a 315 next time around. Did you have to remove the front fender liner?
I'm giving the Hoosiers a go this season. 275f 315r. there's lots of room under there.
Old 03-25-2009, 03:12 PM
NoSubEDU
NoSubEDU's Avatar
275f? You are insane.
Went 225 -> 235. Then tried a 245 but needed to remove the fender lining. Love the tire but can't imagine getting anything wider in there. Already hit the tub on full lock.
Old 03-25-2009, 05:07 PM
kojo911
kojo911's Avatar
Default tires
for what it's worth, I'm running 275s up front and it's really hard to get enough heat in them. My car weights about 2400lbs, but I'm not using much of the fronts. You may be better off w/ a narrower front. My $.02
Old 03-25-2009, 07:21 PM
Full Boost
Why do I feel so left out!
Full Boost's Avatar
Josh,
I have been selling upi a storm on Ebay - trying to clear my garage and junk room out - the new house has F - all storage....
Anyways - as i was clearing stuff out - guess what i found... Some spare fender liners for a 993 .....
Email me !!!
Old 03-25-2009, 07:39 PM
DM993tt
DM993tt's Avatar
I had been running MSPC 265's for years, with fender liners mostly in tact. They got a little rubbed through on the front, but they're in there. Also a tiny bit of rub on full lock, but its rare i get to full lock even around pit and paddock. That said I went on tirerack to check out the R6's and if you look at the dimensions on the site the hoosier 275 measures to a hair less than the 265 mpsc. After buying and comparing this proved to be true. I have no problem getting heat in them either.
Old 03-25-2009, 07:48 PM
Spartan
Spartan's Avatar
Correct 275 R6's are the same size as 265 MPSC. I even get some slight rubbing with 265 PS2's at full lock on my street setup. Oops should say I "used" to get, now I have plenty of clearence for big rubber under my fenders
Old 03-26-2009, 05:02 PM
NoSubEDU
NoSubEDU's Avatar
Weird. Maybe it's my suspension or the way it sits. I can't imagine getting anything wider in front.
I'm not complaining - I'm very happy with the way my car is handling now.
What wheels and offsets are you guys using? I'm using 996TT hollows. I believe I have a 3mm or 5mm spacer in front.
Quick Reply: 2 weeks left until track season starts, figured it was time put the fatty on a diet
