993 Turbo Forum 1995-1998
RS Cam's
Old 08-09-2008, 01:34 AM
pstoppani
pstoppani's Avatar
FYI - Kevin is putting in slightly modified RS cams into my new twin plug 3.8L solid lifter motor. I like the idea of a smoother power band for track work; over the GT2 cams, which I'm sure are a fun kick in the pants!
Old 08-09-2008, 02:57 AM
Jean
Jean's Avatar
There are as many choices of camshafts as names out there.
This is just like saying I have hybrid Garretts and I highly recommend them as they give you great "area under the curve", it is too broad of a statement and does not make sense. Who built them, what A/R, what specs, what components, what engine hardware goes with them, what boost, what ECU tune, what cams, etc..
The same applies to cams, there is no "this is great for the street", this is for 60-130, this is great for 5-60mph It all depends what grind, what hardware, what tunei goes with it and what usage.
The factory "GT2" camshaft alone has at least three different specs that I know of, from street with hydraulic lifters to wild race cams with mechanical, the "RS" is exactly the same, some of them require mechanical rockers others don't. Some of them hold idle at 850RPM, others at 1500RPM.
It all goes together, cams, timing, compression, turbo choice, intake, exhaust etc.. Hence why it is so important to have a custom tune. No one can look at a cam, and say, this will be the best option, it goes with testing and experience with similar builds, and optimizing on the dyno, or just as well by looking at what others did and do exactly the same.
Lack of bottom end response with the GT2 cams is a myth, you find RS cams that are much more aggressive.
So I would not get too hung up about nomenclatures, an RS cam for two different tuners can have night and day differences, unless we talk about the profile of the cam, each one might be talking about a different one and with different hardware and comparing apples to oranges.
Old 08-09-2008, 01:52 PM
Spartan
Spartan's Avatar
After doing some reading on rennsports website it looks like the RS 3.8 cam's profile is
993 RS 3.8 (intake) 240° @ .490" (Exhaust) 226° @ .446" and 110° (lobe center). Would be interesting to see what the stock 993tt cams are so that we can gauge the difference between the two.
Now I'm trying to track down the part number. Anyone have them on hand by chance?
Old 08-09-2008, 03:56 PM
Jean
Jean's Avatar
993 105 247 41 for the 3.8RS
Old 08-09-2008, 11:45 PM
Spartan
Spartan's Avatar
You rock jean thanks!!!
Old 08-10-2008, 10:47 AM
Jean
Jean's Avatar
Spartan,
This number is for the left one, the right side is 993 105 246 41
The numbers that I have are at 1mm clearance (0.039"-0.040"): Intake 238° Exhaust: 230°
Get the stock Carrera 1995 (not varioram), they are almost the same
Old 08-11-2008, 02:37 PM
ScottMellor
ScottMellor's Avatar
I have a build sheet for a different (than mine) Andial 3.8 twinplug car.
The part numbers are the same:
993 105 246 41
993 105 247 41
Old 08-12-2008, 03:28 PM
Spartan
Spartan's Avatar
Can we discuss what valve springs weights would be appropriate for the RS cams?
Old 08-12-2008, 07:25 PM
sfl993t4
sfl993t4's Avatar
Default springs
I'm running Aase springs and Ti retainers from Steve Weiner simply because I wanted a bit more high rpm safety.
I think that Schrick also do an uprated spring kit.
Alternatively the stock springs are probably fine
Steve
Old 08-19-2008, 06:25 PM
Spartan
Spartan's Avatar
Ok now my builder is starting to talk me into GT2 cams
For those of you that DO have mechanical lifters is it worth the extra power and how often must they be re-set/adjusted? My car will see 500 to 1,000 street miles a year with around 20 - 25 track days. If setting the lash was a once a year thing I could live with it otherwise I'd probably just stick with the hydraulics.
Old 08-21-2008, 12:44 AM
Acropora
Acropora's Avatar
As the guys at Kelly Moss would say, it depends on your level of commitment. The short answer is probably once every 2 years at a cost of 800 bucks. If you're like me you'll actually end up spending more on all the other stuff that starts to break at these power levels.
Old 08-21-2008, 11:23 AM
Spartan
Spartan's Avatar
Thanks Acropora. I could live with that, hell I can live with once a year too. Do mind the higher idle with the evo cams? I think the idle is around 1k vs the stock 850 (ish).
Also I'm hosting a private track day at Gingerman Sept 14th if you would like to join us. "Advanced" drivers only, 25 cars max for the event, no run groups, full safety (fire, medical, starter, corner workers) and all the track time you can handle
Shoot me a PM if your interested
Old 08-22-2008, 04:16 PM
pstoppani
pstoppani's Avatar
Kevin at UMW recommends about 10,000 to 15,000 miles for the valve adjustment.
Old 08-22-2008, 07:42 PM
Spartan
Spartan's Avatar
Seems to be in line with what I've read/heard for a street 993tt. Throw in heavy track use and it should probably be once a year. Like I said in my previous post that doesn't bother me all that much as the car can't even be driven for 5 months out of the year with all the Salt they use up here in the winter.
Will you be going the mechanical lifter route with your 3.8 build?
Old 08-22-2008, 08:10 PM
pstoppani
pstoppani's Avatar
Yes. I pretty much need to given the other modifications done to the heads. Plus, I drive the car pretty hard at the track so the solid lifters are safer for the engine.
Quick Reply: RS Cam's
