Cost if Rebuild
Cost if Rebuild
This is a broad question but what is the cost of an engine rebuild. My car doesn't need one as is but I was contemplating an upgrade performance wise and this may be the time for the rebuild. I am not looking to go to a 3.8 or anything like that but a strong 3.6 that can handle Kevin's Stage 2 or a Protomotive package.
We need some further detail on what you want to do. Is this a basic top end job with new rods/rod bolts etc? Or are you going with cams, solid lifters, flame rings, valve work etc (the list goes on and on)
All of these things have a drastic effect on the price of a rebuild. A mild rebuild with a top end job along with new rods should be less than $10k imo (given there are no surprises) but this varies HEAVILY from shop to shop. Call around and ask for quotes, that's what I did. It also gives you a good idea of how each shop approachs what they think is adequate for your power/reliablilty needs. As I mentioned above it varies quite a bit from shop to shop.
Good luck and keep us posted!
I was thinking a basic top end job with new rods/rod bolts etc. I don't know if cams, solid lifters, flame rings, valve work etc would be worth the cost if I wanted Kevin's stage II or a similar Protomotive setup.
There is only 1 local shop so my options are limited but I wouldn't mind driving my car to Protomovie since they are one state over from me.
Give Todd a call and I'm sure he can put together a quote for you
