rear spoiler grill lifting
Hi dudes,
I have a 993tt and annoyingly, the rear spoiler grill lifts at the right hand top corner that is nearest the rear screen... driver side in the UK. Anyone else had this? looking down into the fixing to see how it should sit, it seems there is just a small clip that clips into a recess which is not particularily deep...hence the grill pops up every now and again....
look forward to hearing your thoughts..
yes, a common problem I think. IIRC, there is a kit to reinforce that part of the grill... couldn't find anything here on the TT forum, just this thread with the same problem. https://rennlist.com/forums/showthre...ferrerid=35947
Hope this helps.
Someone else may have more to add... like an answer maybe...
EDIT: found this: https://rennlist.com/forums/showthre...ferrerid=35947
Hope this helps.
Thanks for the replies.
Is there a kit available from Porsche? Just wondering where you would get the stainless or aluminium strip from. I can't really read the article as the scan is a poor quality, but does it mention which glue to use?
If you can scan the article again JDHertz11 that would be much appreciated.
thanks.
thanks.
Unless maybe yours will be easier to read?
thanks.
thanks.
I'd bet someone here knows. I don;t know the anatomy of this grill that well. Fortunately, I have not had to deal with this... yet.
