Best coilovers for 993TT
What is the best coilover for a '96 993 TT. It is primarily a street car at the moment, but I want the flexibility to have a great track set up.
RL Technical Advisor
One would need to know a good deal about your driving experience for a more definitive answer, but you couldn't go wrong with a PSS-9 setup for street and track work.
Here's an interesting test of the PSS9's, don't know if anything like this has been conducted here before (edit yes it has and I've included a link)
http://forums.audiworld.com/suspension/msgs/1121.phtml
Here is the link for the Rennlist post
https://rennlist.com/forums/showpost...0&postcount=12
The findings on the first link were that there were only two true different settings on the shocks. Regardless they are still great all around CO's and decently priced but you really can't compare them to Ohlin, Penske, Motons imo. Then again you get what you pay for as those offerings are twice the price if not more!
IMO even on the street a properly set up combo from Ohlin, Penske, Moton with MUCH higher spring rates than PSS9's are just as comfortable. I'm driving on crappy Chicago roads too, not the perfect pavement found in more sunny climates
Not trying to start a sht storm here but thought that it may be good for discussion
Suspension settings are so subjective. One man's firm is another man's soft. I think it boils down to what's tolerable to each individual.
But I think for sure is that the stock suspension and PSS9s can be compared to night and day.
Lastly, where one choices to stand on the "cost no object" to "on a budget" line is also a determining factor. One needs to decide how "far" they want to take it.
JMHO
This is what i did. Car handles like a go kart : )
Porsche RSR Bilstein shocks revalved by Bilstein to match higher spring rates
Hypercoil 900 – 600 lb springs
MODE Design camber plate / monoball uppers in the rear
ERP monoball / camber plates up front
Factory Motorsports strut tower brace
RS rear adjustable sway bar (3 way)
RS 5 way adj front sway bar
ERP Front lower control arm monoballs (replaced the OEM rubber ones)
ERP rear adjustable links, Kinematic, tow, camber, and monoballs in lower control arm
ERP solid Carriage Mounts
GT2 Evo Uprights
ERP bump steer kit
GT2 Evo Uprights
ERP bump steer kit
My current set up is similar to AndyT, with the exception of the springs.and front bar (mines a 3 way) I run twin springs 150/800 and 125/600 Eibach. This give almost decent street ride without a kidney belt for the street. This set up will run down Lotus's in the corners.
I will be changing to a KW set up shortly.
Why do I feel so left out!
JIC - Only way to fly!
Simon.
Simon.
