993 Turbo Forum 1995-1998
Replacement for heater tube rubber sleeve
Old 05-29-2007, 11:52 AM
johnneurauter
johnneurauter's Avatar
Default Replacement for heater tube rubber sleeve
I need to replace the orange rubber sleeves that connect the cats to the heater tube and the heat exchangers.
Can anyone recommend something for me that's capable of dealing with the heat down there? I need something a tiny bit longer than what's stock.
Old 05-29-2007, 03:23 PM
Felix
Rennlist Lifetime Member
Felix's Avatar
I think it comes in bulk (by the meter) from Porsche. But I think it's also quite expensive.
Old 05-29-2007, 03:35 PM
Dudley
Dudley's Avatar
There are a few guys on the 993 board looking for the same hose. You could buy a 1 meter hose from Sunset, cut off what you need and sell the rest. I figured $17 for two 45 mm hose sections including postage when I did the same thing some time ago. If I remember correctly, the whole piece was $172.
Old 05-29-2007, 07:49 PM
iborroel
iborroel's Avatar
Last time I checked at the local Porsche dealer it was expensive for how much hose you got. I decided to pass and kept what I currently have. I'm surprised there aren't alternatives available.
Old 05-29-2007, 09:08 PM
sfbanchs
sfbanchs's Avatar
i found this heater sleeve at napa auto parts it was 90 bucks or something like that but identical to the factory one
Old 05-29-2007, 09:45 PM
iborroel
iborroel's Avatar
How was the fitment?
Old 05-31-2007, 06:32 PM
sfbanchs
sfbanchs's Avatar
fit perfect actually and is orange liek the factory ones
Old 05-31-2007, 07:59 PM
md11plt
md11plt's Avatar
Sebastian,
Any chance you have a part number?
Old 05-31-2007, 08:09 PM
sfbanchs
sfbanchs's Avatar
actually no i went ot napa brought the guy out to my car had him squat way down so he could see that one side had one and the other didn't and he knew exactly the one to get me, if you have a local napa in your area they should be bale to identify it and if they don't have one order it
Old 05-31-2007, 08:32 PM
md11plt
md11plt's Avatar
Thanks. How long was it? How much of the stock stuff did you replace for the 90 bucks?
Old 05-31-2007, 09:13 PM
sfbanchs
sfbanchs's Avatar
i replaced the one on the left side from heat exchanger to the heatrer bleed valve and the one from the heater bleed valve to the other end i forgot the name, the sleeve i bought from napa was long enough for both and i used a razor blade to cut it and obviously used clamps, i dont really need the heat in miami but the engine sounded cleaner with the piece on rather than off. and of course i am **** with my TT
Old 06-01-2007, 09:43 AM
md11plt
md11plt's Avatar
Old 06-04-2007, 01:15 PM
johnneurauter
Been striking out on this search, found something at McMaster though that looks like it should work. If anyone's interested, I'm ordering up 5" ID and 3" ID sections of the stuff on page 199 of their catalog:
From their site (no affiliation):
<snip>
Crushproof Rubber Duct Hose for Exhaust Fumes
* Use with exhaust fumes
* Temperature: Up to 600° F
* Flexibility: Flexible
* Abrasion Resistance: Excellent
* Compresses 80% of extended length
* Color: Black
* Material Meets: Not rated
Carry carbon-monoxide exhaust fumes to underground, overhead, and through-the-door outlets. This crushproof, EPDM rubber hose is ideal for garage exhaust environments as well as for high-temperature applications. Material thickness is 0.10". Hose does not have a support and is not rated for pressure or vacuum. Can be used outdoors. Supplied in 11-ft. sections.
</snip>
So I'll obviously have some extra. I'll let y'all know if it works.
Thanks for the help.
John
Old 06-04-2007, 03:53 PM
sfbanchs
sfbanchs's Avatar
i'd be interested if you have extra let me know, maybe you can give it to me in chitown next weekend
Old 06-04-2007, 05:02 PM
johnneurauter
Actually back on the hunt. Been told that rubber will harden and crack. They do have a silicon duct as well on page 193 I believe, but it was a wire skeleton, which should be okay, but I was trying to get as close to stock as possible.
Quick Reply: Replacement for heater tube rubber sleeve
