Improvements while not changing the ECU
what improvements can be done without modding the ECU. I must keep my OEM ECU to run in PCA C stock Club Racing. I have muffler bypasses and that's it so far. My turbos are going to need rebuilding and I was thinking of sport cats or no cats. I already have a BMC air filter too. Can I improve power without chaning the programming ? Headers, cats, ignition wires...anything ?
RL Technical Advisor
Andy:
If you cannot touch the ECU, then all you can do is concentrate on the exhaust system and the reduction of back pressure.
Special wires, headers and all that stuff is a waste of time: stock is fine.
Make sure the turbo's are in perfect condition and the wastegate actuators are adjusted correctly.
The rest of your success in that venue lies with the suspension configuration/preparation and the driver,.....
How about suspension??
that is where Mr. Weiner can REALLY help you!!
Other than that, I believe my local buddy that ran his 993TT had those horrible sounding
muffler bypasses. (funny thing is some people think this is the greatest exhuast system ever)
MK
MK
Originally Posted by AndyT
thanks Steve.
Felix:
I think there are some possibilities there although perhaps a "blueprinted" set of stock K-16's would suffice. One must read the rule book very carefully to see the language used to specify what cannot be done,......
i think my turbos are toast at this point. 57k on them and 20k of that track I'd say. I'm going to send them out for a rebuild. Upgrade to the orange ended intercooler hoses. Maybe some diverter valves and run an open exhaust. Just dump pipes. All this to be done after a leakdown by the advise of some wise Porsche gurus : )
Folks,
Excuse my ignorance but what is the impact of the upgrade to the orange ended intercooler hoses? I tought they were just more solid/reliable and I would like to understand why it is an interesting upgrade performance wise??
Thanks!
Pierre
Thanks!
Pierre
What about weight reduction? What have you done so far besides dropping the mufflers?
Some things to do and consider even before you mod the engine:
-race seats
-RS door liners; the stock door trim is pretty darn heavy with the large speaker magnets and all
-remove rear wiper assembly
-remove rear seats
-remove seat belt retractors
-lighter drycell battery
-lightweight flywheel
-remove front differential for two wheel drive(not sure if that will violate the C stock rules.
-light wheels
-suspension(as Woodster added)
-add aux cooler, billet diverter valves
-race seats
-remove rear seats
-light wheels
Pierre : orange ended hoses are mearly a reliablity part.
Mike H: battery is on order from Rennline : )
Ok here's the list of how the car sits now
Recaro SPG Pro Racer Hans Driver seat with sliders
SPG Passenger side seat
Schroth Profi 6 harnesses
Momo Porsche SuperCup Steering Wheel (horn operates)
TC snap off steering wheel hub
Safety Devices Full Cage
Brey Kraus Seat Back brace
Fire extinguisher and BK mount
SFI Rollbar padding
RS door panels
RS shift ****
RS brake handle
930 style manual Boost gauge (clock still connected behind the dash)
RS console package tray replaces cassette holder.
Rear wiper delete
Airbag disabled on the a passenger side
Hot lap with smaller display unit.
Radio is not working because we pulled the amp out to get the sub belts in the correct spot.
Renline RSR floorboard on the drivers side along with Ultimate Pedals. Really nice, not cheesy
Porsche RSR Bilstein shocks revalved by Bilstein to match higher spring rates
Hypercoil 900 – 600 lb springs
MODE Design camber plates / monoball uppers
Porsche Factory strut tower brace
RS rear adjustable sway bar (3 way)
TRG 5 way adj 25mm front bar
ERP Front lower control arm monoballs (replaced the junk rubber ones)
RS Lightweight Flywheel
RS pressure plate
GT2 clutch disc
RS motor mounts
Pagid Yellow / Black pads
Fischer Stainless lines
Pentosin racing brake fluid
Euro front bumper cover Factory part
GT2 Carbon splitter – Getty Designs
Factory brake ducts to the wheel wells
Factory smaller fogs
2 sets of BBS Mag wheels 18 by 9 and 18 by 11.5
One set in Gold one set Silver
Hooisers 305 and 245
Breather modification to keep oil out of the intercooler
Intake air temp modification
BMC air filter
Mobil One
Fabspeed muffler bypasses (mufflers included)
Just had a power steering line replaced on me and the motor was resealed last year.
No leaks, never smoked blue smoke
SFI Rollbar padding
RS door panels
RS shift ****
RS brake handle
Rear wiper delete
RS pressure plate
GT2 clutch disc
RS motor mounts
BMC air filter
Mobil One
wow... more than slippery to me
