Only get .7 Bar
Only get .7 Bar
I have a 96 TT Gemballa modified car with an ECU mod and it only registers .7 bar max. Could that be a computer problem or is it more likely an indication problem. The car is faster than a stock 97TT. But it will always hit .7 bar. Any ideas on what it could be?
The computer is limited to display .8 bar, even if you are getting more boost.
A fix around this problem is to get a boost gague that is a drop in replacement for the clock. That will give you an accurate measure of boost.
Jeff
Jeff
