AP-22 results with Ruf Turbo R
Here's the results from an AP-22 accelerometer on a Ruf Turbo R from 0-120 MPH. Started at 2500 RPM with an easy slip-clutch launch, shifted at 6800. This is the first time I tested the car from 0 MPH:
Start Speed 0.0mph
mph s g ft hp
10.0 0.82 0.57 5 34
20.0 1.64 0.62 23 74
30.0 2.16 0.95 42 171
40.0 2.92 0.52 82 130
50.0 3.58 0.71 126 220
60.0 4.24 0.68 179 257
70.0 5.34 0.33 286 163
80.0 6.20 0.55 381 296
90.0 7.08 0.49 491 315
100.0 8.45 0.40 682 308
110.0 9.48 0.41 841 362
120.0 10.62 0.38 1034 390
Pk Power: 118.3mph 10.42s 999ft 392hp
Peak G: 31.8mph 2.24s 46ft 0.95g
I didn't calibrate the car weight, so the HP will be off. However, the speed and times should be fairly accurate.
Start Speed 0.0mph
mph s g ft hp
10.0 0.82 0.57 5 34
If anyone's interested, here's the AP-22 capture file:
<a href="http://boards.rennlist.com/upload/0_120.cap" target="_blank">http://boards.rennlist.com/upload/0_120.cap</a>
Thanks for the post. If you don't mind me asking how much did it cost you total to get the Ruf conversion? I'm thinking of doing it but debating whether to ship to car to Ruf or having it done locally. If you don't want to divulge the cost on the board, please e mail me the rough breakdown. Thanks in advance. All this cold weather got me thinking about what I could do for the car while it sits awaiting the warm and salt free Michigan weather.
Vince
Vince
Bill
Good work thanks for sharing. If you had managed an optimal start and reached 60 in 3.7secs (which is what the magazines managed on a stock tt) then you would be hitting 100mph in under 8 seconds -that is fast.
Can you tell me how and where you have attached the meter to the car. Now my engine is run in, and the temperatures are nice and low, I will do some runs <img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" />
Vinrey,
Search this discussion board for "turbo r conversion". You'll see some of my last posts regarding the cost and conversion details, including photos.
tb993tt,
I agree about the 0-60. An editor at Road and Track Magazine told me they got 0-60 in 3.3 seconds. However, I've never seen this number published for a Ruf Turbo R.
I mounted the AP-22 on the floor of the glove-box, butted-up against the rear wall, and held in place with the 2" Scotch long-mask tape. I think the Scotch tape will also hold it well to the high point of the dash above the gauges. You might also try mounting to the open glove-box cover back. It's tough to find a flat surface to mount without damaging the finish. Thanks again for your recommendation on the AP-22. It's a fine piece of equipment.
tb993tt,
I have an AP22 as well and have managed a 3.99 sec to 60 in a standard car and I actually felt there was a bit more to come but didnt really feel like unleashing the type of brutality needed to achieve it.
TB the AP22 doesnt attach to the car at all its just an accelerometer, I think you are in the northwest somewhere, as am I, so if you would like a borrow let me know.
Si
Si
Si
Si
It doesn't attach
So it just rattles around the floor <img border="0" alt="[ouch]" title="" src="graemlins/c.gif" />
Just kidding, for "attached" read "secured" .Thanks for the offer, I have one and I was just asking Bill S where he "attaches" his because with over 1G of acceleration it needs to be pretty secure.
It doesn't attach
Ha,
Sorry I misinterpreted your post. I struggled to get a good point too, even with the sticky things I felt the wobble might corrupt the reading. I settled for a passenger pressing it down and holding it firm, so there was also a little bit of extra weight in the run. How accurate do you think these are ? I managed to get over 1g ( lateral ) on the M60 exit to the M56 ( Princes Parkway ) if you know that, reckless yes but I just had to know. I dont think that figure is to be trusted though.
Si
Si
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by simaloney:
<strong>Ha,
Si</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">1g of lateral is quite easily accomplished on certain streets, when magazines test skid pad numbers they are on a level surface with a specific radius. Most on ramps and exit ramps are banked which allow significantly more grip.
<strong>Ha,
Here's a 0-150 MPH run (15.3 seconds) with a Ruf Turbo R. Run done with 91 octane gas, one 190 lb driver:
Start Speed 0.0mph
mph s g ft hp
10.0 0.84 0.57 5 34
40.0 2.97 0.42 85 106
50.0 3.68 0.70 132 217
60.0 4.31 0.69 183 262
70.0 5.39 0.37 287 181
80.0 6.23 0.57 380 310
90.0 7.10 0.48 489 311
100.0 8.43 0.42 674 321
110.0 9.47 0.41 835 358
120.0 10.60 0.39 1026 395
130.0 12.40 0.21 1360 319
140.0 13.79 0.31 1635 449
150.0 15.30 0.30 1957 494
Pk Power: 150.0mph 15.30s 1957ft 494hp
Peak G: 33.0mph 2.30s 48ft 0.96g
AP-22 was mounted on the high part of the dash with 2" 3M long-mask blue tape.
Start Speed 0.0mph
mph s g ft hp
10.0 0.84 0.57 5 34
I have the new G-Tech Pro Competition and recorded the following times on my 993tt:
0-60 3.9 secs
1/4 mile 12.17 @126.2 mph
The tires were cold and had alot of pressure in them, so the launch was alot of wheelspin in first gear, even leaving at 2000 rpm. With hot tires and less pressure, I'm sure I could leave at 3000-4000 rpm and get in the 3.7 range. The trap speed seemed a bit high to me, but the car is slightly modified and putting out about 430 hp.
<strong>I have an AP22 as well and have managed a 3.99 sec to 60 in a standard car and I actually felt there was a bit more to come but didnt really feel like unleashing the type of brutality needed to achieve it.
0-60 3.9 secs
Dan,
Can you download your time, speed, distance and G from the G-Tech to post here in 10 MPH increments from 0 to 120 MPH? This makes it easier to compare (I don't know if the G-Tech could do that). Your 126.2 MPH does seem high for your "slight" mods.
Dan
That does look high for 430hp - it looks like you 0-200kph (124mph) would be about 12 seconds - that usually takes in excess of 500hp for our cars weighing over 1500kg. Techart claim 0-200kph in 12 secs for their 700hp 996 based GT street !!
I have heard in certain circles that the G-Tech is not as accurate as claimed. Any substance to this?
TB933tt:
Was your car at tech9 July last year? Pretty sure i saw it there around that time?
BR/Phil...
TB933tt:
BR/Phil...
