Passenger front spark plug change advise needed!
I am having an issue with the passenger side front spark plug wire! I have the cover off but can not pull the boot off of the plug!! I can pull approximately 3/4's of the boot out until the top of the boot makes contact w/ the "engine mounting bracket" and the annoying purposeless engine tin. I'm thinking about just cutting the boot and puttting a new one on. Any advise????
Thanks,
Thanks,
Tim you need to bend the boot a little.. As you pull it out, lift it toward the top of the engine. If your plug wires are rigid and stiff you might think about replacing them..
I find it easier to pull the right rear tire and with the rear tin removed it makes it a little easier to get it from the side vs on top.
