smoke at start up ?
smoke at start up ?
96' 993TT smokes at start up, then stops after a minute or so, doesn't do it when the car is already warmed up. I heard the turbos are lower than the eng. and after sitting a while, oil can get in the turbos causing burn off at start up. any truth to this ? Please help, please
D. W.
D. W.
I heard the turbos are lower than the eng................
Smoke 1
Smoke 2
Smoke 3
Depending on the details of your problem (recent oil change, milage, smoke color, leaks.....etc) the problem can range from normal, to bad oil filters, to blown turbos, to...very bad).
Maybe you can change your username after you solve the problem....
