993 Turbo Forum 1995-1998
Will running 235/40's w/ 285/30's ruin the viscous coupler?
Old 06-14-2005, 03:35 AM
Acropora
Acropora's Avatar
Default Will running 235/40's w/ 285/30's ruin the viscous coupler?
Just wondering now that the 235/40's are already on the way...
Old 06-14-2005, 04:31 AM
adsc4s
adsc4s's Avatar
It will be fine. The difference in diameter is minimal.
Old 06-14-2005, 12:08 PM
ScottMellor
ScottMellor's Avatar
It takes more than THAT to toast a VC. Ask me how I know.......
As I understand it the front tire diameter should be slightly smaller than the rear to "pre-load" the VC so it is putting 5% of the power to the fronts in normal driving.
Old 06-14-2005, 06:37 PM
EThec
EThec's Avatar
i think it's the other way around. you want the rears slightly smaller so they are spinning just a little faster. 225X.40=94 ..... 285x.30=85.5 with aspect ratio(sidewall height) being a percent function of section width.
but with respect to this thread, i was curious about running 235's and 285's and the consensus is it is not a problem. The difference between 225 vs. 235 is negligible and others have done it without any issues. don't take my word for it though. i have not done it............
Old 06-14-2005, 07:55 PM
ScottMellor
Oops right. Rears smaller. My bad.
Old 06-14-2005, 11:51 PM
adsc4s
adsc4s's Avatar
I've run 295/30 with 225/40 on my C4S with no problems. I've run the same combo on my TT as well. I currently run 235/40 with 315/30 in 18's (which I believe Viperbob and CJ do as well) and 245/35 with 285/30 in 19's. Of course, my VC is toast. Unlike Scott, I have yet to fix mine.
Old 06-15-2005, 02:39 AM
DJF1
DJF1's Avatar
While I cannot say for sure about the 4 wheel system effects, at the club race in Sebring this winter, I met the Michelin engineer on track. Told him about my understeer issues and he said to me that I actually had 2 problems. One the track temp as it was very cool and the MPSC's love 200 degrees and the 2nd issue was my 225's fronts. He said that I should combine my rears ( 285's) with 235's in the front and I should get great results. I asked him about the diameter difference and he told me its not an issue and that many of his customers who have tried this combo have had great resluts.
Old 06-15-2005, 04:57 AM
Jean
Jean's Avatar
I used 245 front and 275 rear on my previous C4 and it run perfectly well. Understeer was completely cured, no sway bars or any other changes. Steering was a bit heavier, but it ran great and tramlined like a pig Some say is too much but this is my experience.
I am now running 265 upfront, no understeer, and no issues with my VC. Oh! I don't have one
Old 06-19-2005, 03:16 AM
Vince 97' 993 TT
Vince 97' 993 TT's Avatar
Question
So does everyone experience tramlining in their rides? It sux, expecially under hard braking... Is there anything that can be done to correct this?
Old 06-19-2005, 11:47 PM
pstoppani
pstoppani's Avatar
Other than staying out of the ruts? Not really, if you want the car to handle well in other circumstances...
Old 06-20-2005, 02:13 AM
Jean
Jean's Avatar
Vince you can change the Toe settings and it will help, advise given by Viken some time back. I am not sure how much or which way sorry. If you run a search for tramlining you should be able to find something.
Quick Reply: Will running 235/40's w/ 285/30's ruin the viscous coupler?
