993 Turbo Forum 1995-1998
Exhaust Options?
Old 08-17-2004, 12:29 PM
tlark
tlark's Avatar
Default Exhaust Options?
While my car hasn't arrived yet, I have read through hundreds of threads in regards to the exhaust note of the tt. It appears that my stock exhaust will have to be changed in order to hear a enhanced engine note. My last car had a Tubi on it and I loved it, but it looks like many manufactures offer products for the Porsche at less cost than a Tubi and able to deliver a sound I would enjoy.
Those familar w/the Tubi know it as a low baratone sound that isn't annoying to the neighbors yet you know its there and it has the ability to scream like a scalded cat at WOT. I assume other more costly mods may be coming to this "go fast crack pipe" and would like a few reccomendations on the sound I desire at a reasonable cost so $ can be used for other uses. I have ideas via research, but others have more personal experience than I.
Don't use paypal, someone PM me on a address to send $ to join the forum!
Old 08-17-2004, 01:03 PM
LT1
LT1's Avatar
Fabspeed muffler bypasses! $525ish from Viperbob. My favorite mod yet
Old 08-17-2004, 02:52 PM
seege
seege's Avatar
I have the Fabspeed bypasses and I love them alot more than my neighbors do.
I'm looking for something a little subdued at low revs(in the neighborhood) but with that crackle when I'm on it. I've also tried Fabspeed Maxflos, but they're not much louder than stock. I know the Supercups wail too loud so that rules out Fabspeed for me. If RSR's are made for turbos that may be the answer.
Good luck Tom
Old 08-17-2004, 02:56 PM
nman413
nman413's Avatar
Tom, PM John D. He's the poobah of rennlist
I second the muffler bypass recommendation. They sound great and add hp (some). Turbos should not come in any other way.
Old 08-17-2004, 03:03 PM
nman413
nman413's Avatar
CJ, RSRs are indeed available for Turbos. Take your neighbours for a ride and that should help convince them of why you MUST have bypasses
I'm thinking the bypasses are too quiet. Maybe cat bypasses are in my future....
Old 08-17-2004, 04:17 PM
mkhn
mkhn's Avatar
Also, don't forget the benefits of dropping a few lbs. The stock mufflers weigh about 40lbs together and their location at the back corners of the car can't be good for handling. I forgot to weigh the actual Fabspeed tips, but should be near a couple of lbs each.
Old 08-17-2004, 06:41 PM
rinlv1
rinlv1's Avatar
What about the RSR mufflers?? Anyone using them?? How do they sound compare to Fabspeed bypass or stock??
Old 08-17-2004, 06:53 PM
Bull993tt
Bull993tt's Avatar
I have a CarGraphic Cat By-Pass and Turbo RSR's. I love the sound. It is not to loud but gives a tight rich exhaust note that is a joy to the ears. It is the way the car should have sounded from the factory. The only thing that I didn't like was that my car lost 3hp at the rear wheels from my stock cats and mufflers. It went from 385hp to 382 hp and torque dropped from 420 fp to 412fp. It sure sounds faster though... such is life.
Bull Schwarz
Baltimore, MD
PCA Chesapeake Region
'96 993 tt
'94 968
'77 911s
'02 BMW M3
'97 Landrover
Old 08-18-2004, 05:07 AM
MOD500
MOD500's Avatar
Have a Techart sports exhaust and hi-flow cats on mine, is ok at low revs when taking it steady round town, etc. Though when the turbos light up there is a mighty roar and bellow generated, I love the whooossshhhhhhhhhhh sound too of the exhaust gases been forced out of the pipes as you near the rev limiter......but maybe I am a little sad!!
Have never heard a TT equipped with a Fabspeed by-pass muffler, etc and am very unterested to hear one.
Best Regards
Martyn.
Old 08-18-2004, 07:55 AM
Jean
Jean's Avatar
Your best bet for performance and sound would be to have cat- bypass pipes for quick spooling and a low restriction custom muffler, lighter and less restrictive than stock. Sport Catalytics don't seem to deliver to their promises.
If you are into customization, get a fabspeed cat bypass pipe or similar and you might want to try out these mufflers, I know the sound is very nice but no idea about performance gains.
http://www.aero-turbine.com/buy/details_3030.html
Here is how they work
http://www.aero-turbine.com/how/index.html
Here are the manufacturer's claims
http://www.aero-turbine.com/benefits/index.html
Here is the sound
http://www.aero-turbine.com/seehear/index.html
And here is the disclaimer: I have not tried them or have anything to do with this company.
Jean
Old 08-18-2004, 12:07 PM
viperbob
Former Vendor
viperbob's Avatar
Jean - On our cars, where would you put that? I have cat bypasses and found a billet race muffler that I installed in place of the heater pod of the exhaust. So my exhaust is loud, and I have no heat. There really is not another place to install it unless you connect it to the cat pipe and stick it in the muffler area with some mandrel bends.
Old 08-18-2004, 03:41 PM
Jean
Jean's Avatar
Bob,
It looks bigger than what is is. Here is how it can be fitted, this pic is on a 930.
Old 08-18-2004, 04:37 PM
viperbob
Former Vendor
viperbob's Avatar
This is similar to the way I have mine set up with the smaller mufflers. The issue is, do turbo owners want to have not heat option?
Old 08-18-2004, 04:50 PM
Anir
Anir's Avatar
I second the vote for muffler bypasses - I have the ones by GHL. As others have mentioned, you get the great sound and remove 30 lbs from each of the rear corners while allowing quicker spool-up on your turbos. A bit loud for some, but otherwise a perfect mod.
Old 08-18-2004, 05:05 PM
Jean
Jean's Avatar
Heater Oh yes, I never thought that some might have this issue
Quick Reply: Exhaust Options?
