Help: LED Boost/Trip Odo/etc bulb out
The lighting of the multi-function LED gauge in the tach that shows the boost/MPH/outside temp/etc is out. Sometimes it goes on, then out. I can see that the LED is still working, but it's not lit, so very hard to see. Anyone know what the drill is to replace the bulb. Hopefully it's only the bulb. Any help would be appreciated. Thanks is advance.
This should not necessary.
Use a cloth to protect the guage and using the clock as a brace, slide a screwdriver under the speedometer and pop it out. Once that is out, you can reach behind and pop the tach out.
