clutch pedal pressure question
For starters I am new to both 993's and turbo cars, so please forgive me....
I had a 96 993tt (40,000 mile car) this past weekend for an extended test drive. One thing that felt strange to me was the variation of the pressure needed to push the clutch in.
I would say on 5 out of 10 times I depressed the clutch it felt very smooth and light with little pressure needed to push it in. On the other 5 out of 10 times (just a ball park) it felt very stiff to push in and required about 5 times the force to depress it as the previous times. It seemed to change with no pattern (car hot, cold, etc).
Is this normal, or do I need to worry?
-ps- yes the car will have a ppi before I buy it
No, not normal. The 993TT has a boosted clutch, and very complicated hydraulic circuit. My uneducated guess is that the hydraulics are clogged, dirty, or ready for a new slave cylinder. Not a horribly big deal. Search on this forum... someone else had a similar problem about 6 weeks ago.
Originally posted by msw
Erik,
Are your clutch problems fixed?
Mike
Erik,
Mike
/E
I had the same problem. I had a bad power steering pump. You'll ask what does the power steering have to do which the clutch. Well the hydraulics are connected.
JW
'96 993tt 3.8
'86 930
'92 968 race
'89 944 race
JW
'96 993tt 3.8
'86 930
'92 968 race
'89 944 race
DV 993tt: Didn't you have any problems with the steering? Was it just the clutch?
Please correct me if I'm wrong anyone!
/E
Erik
I didn't have any problems with the steering. It was only the clutch.
JW
Erik
JW
Still, I would go for the acc first because that's way cheapest. Second, the slave cylinder because it will need to be changed sooner or later anyway. Third, the pump. I heard that the pump is a expensive SOB.
/E
